2 Pages V  < 1 2
> My New 5sfe Header, 5sfe headers finally installed...
post Sep 24, 2007 - 4:13 AM
Razgriz
Joined Jan 22, '07
From phoenix, AZ
after you guys install new headers do you re-install your heatshield? or do you just wrap the pipes, or both?
i would probably go heat shield and wraps if not just for the fact to make it look stock.
post Sep 24, 2007 - 7:32 AM
Redline08
Joined Feb 23, '07
From Albany, NY
you wont be able to fit the stock heat shield back on... easily.
Wrapping them is the way to go : )
post Sep 25, 2007 - 12:14 AM
Razgriz
Joined Jan 22, '07
From phoenix, AZ
QUOTE(Redline08 @ Sep 24, 2007 - 12:32 PM) [snapback]598542[/snapback]
after looking at the pictures again i was beginning to think so. thanks for the clarification though.
post Sep 25, 2007 - 8:26 AM
frosty
Joined Sep 1, '04
From Alabama
Yeah, it would be nice to be able to fit the heat shield back on as for daily-driving protection and for shows take it off and show them pipes.
So, did the girlfriend get some major brownie-points for this buy?
CLOSED on 25 acres!
-shop coming soon....
post Nov 19, 2007 - 12:00 AM
DeW_H0e_GT
Joined Mar 9, '05
From Oakland, Cali
did everything went in okay?...like did everything bolted on easily?.....i really dont wanan take this to a muffler shop to have it welded on to the cat......
QUOTE(DeW_H0e_GT @ Nov 19, 2007 - 12:00 AM) [snapback]615512[/snapback]
This post has been edited by DeW_H0e_GT: Nov 19, 2007 - 12:00 AM
post Nov 21, 2007 - 2:02 PM
dfolz3
Joined Nov 21, '07
From WI
Nice job on the install. I also saw this on E-Bay.
I'm interested in one but do you know if this is smog legal? I live in a state that requires emissions check.
I see the header has ports for O2 but is there not a pre-cat on the OEM manifold?!
Thanks
post Nov 21, 2007 - 2:05 PM
LewFX
Joined Jan 28, '05
From Redondo Beach, CA
no headers are smog legal that ive seen
post Nov 27, 2007 - 1:41 PM
dfolz3
Joined Nov 21, '07
From WI
Yes, you are right, so I'll reword my question to k-weaver.
Does your Toy pass emmisions? I see there are ports for the O2 & EGR.
My concern is that the pre-cat is removed with the stock ex manifold, therefore would not pass emmisions?!
Any comments or does any body else have a 5sfe w/headers and know about emmisions?
My 4Runner has headers and it passes, but it doesn't have a pre-cat.
post Feb 9, 2008 - 5:51 PM
Celicav
From Virginia
smile.gif I ordered one of these Ebay headers and it has been received. Due to my perfectionist nature, I had PMed a few of the people that have installed this header (including k weaver) b/c I was worried that the bolt holes on the header looked off, and not centered with the surrounding metal design. So, although I have not installed it yet, I have concluded that I should not worry. So I spent a couple hours under the hood, and found the manifold studs anchored to the block are 10 mm wide, while the holes that the studs go through on the header are like 14 mm! That should definitely leave some tolerance if your holes look like they off kilter when you receive your header.
Also, in reference to the first big, O2 sensor, with the oval shape and attached by the two studs...well the hole on the header is not perfectly center between the two studs that the O2 sensor attaches on. After studying the stock set up, this is how it is anyways...there is about an 1/8" difference from middle of the sensor to one stud, and from the middle of the sensor to the other stud.
These are just some preliminary observations before I actually install this very inexpensive header...but the quality seems to be pretty good. If I run into any other issues or find any other technical info to share, I will do that. And pics to be added once it is installed.
One question: Should I expect any CEL code to be thrown, or will everything be okay as long as both sensors are plugged in?
My impression is that although we are removing the pre-cat, it really only "covers" for the main cat under the car until it warms up and starts doing its job. So without the pre-cat, we are really only throwing unnecessary pollutants out for a little bit of time after starting the car. Let me know if I am off base.
post Feb 12, 2008 - 11:15 AM
nightryder
Joined Sep 29, '05
From Rochester, Massachusetts
it shouldn't throw a CEL. I have the cali emissions engine and I couldnt get one of the 02's out of the old manifold, so I used the plug (that conveniently came with the header) and screwed it in the hole.
The question is not how far. The question is, do you possess the constitution, the depth of faith, to go as far as is needed?
post Feb 12, 2008 - 11:43 AM
Tigawoods
Joined Dec 22, '06
From Columbia, MD
wrap it bro, after a while i looks like it got cancer. mine is in need of it frown.gif
エキサイティングカーレーシングチーム!
post Feb 12, 2008 - 11:44 PM
nightryder
Joined Sep 29, '05
QUOTE(Tigawoods @ Feb 12, 2008 - 11:43 AM) [snapback]640705[/snapback]
x2
post Feb 13, 2008 - 11:38 AM
kenjamatic
Joined May 20, '05
From sacramento, ca
nice set of headerz...jus like the ones i used to have....ur car do get louder, picks up much better and the chrome will start chipping off XD...wrapping it isn't necessary, its really up to u....no codes will b thrown and it won't pass emissions/smog but its pretty easy to take off and put back on(the sensor is a bi*ch to take out and put on). No you dont need to get anything welded but u do need to get some bolts...heat sheild won't fit coz the aftermarket headerz don't have the holes for tht screws to go into...if u wanna c picz check my profile of my baby b4 i got n a accident =(...
edit: forgot to mention after i had cai, headerz, cat bak exhaust my MPG's improved XD...went from 300mi/tank to 380mi/tank...
This post has been edited by kenjamatic: Feb 13, 2008 - 11:40 AM
post Feb 13, 2008 - 11:53 AM
QUOTE(kenjamatic @ Feb 13, 2008 - 11:38 AM) [snapback]641082[/snapback]
headerz...headerz headerz,
you only have one header, not more than one.
post Feb 13, 2008 - 12:03 PM
kenjamatic
Joined May 20, '05
From sacramento, ca
QUOTE(Batman722 @ Feb 13, 2008 - 8:53 AM) [snapback]641088[/snapback]
lol...u knew wat i meant...XD
This post has been edited by kenjamatic: Feb 13, 2008 - 12:03 PM
post Feb 14, 2008 - 5:46 PM
MyFreeCamry
Joined Jan 4, '08
From Lexington, KY
QUICK TIP.... for anyone else that wants to install a polished header....if you do not use gloves when installing and then start up, your fingerprints will be burned into the header making it look ugly. If you do not have gloves to use, wipe the header down with rubbing alcohol just before startup......
post Mar 11, 2008 - 7:53 PM
Etak28
Joined Sep 2, '06
From Mechanicsburg, PA
I just bought this header and was told that it takes off the second cat. That's fine but for our cars the garage said it will throw off an immediate check engine light unless you got something that sends a false signal from that sensor. Does this really happen because I'm afraid to install it if I'm not going to pass emissions due to a faulty sensor?
'99 Celica GT - White
Etak28
post Mar 11, 2008 - 10:49 PM
Celicav
From Virginia
QUOTE(Etak28 @ Mar 11, 2008 - 5:53 PM) [snapback]652255[/snapback]
You should be fine. Make sure you install both O2 sensors back onto the header. I've had mine on for a few weeks and no problems yet. But I guess a select few have had issues, if you do a search on here. But you can erase the code later if you get the problem.
This post has been edited by Celicav: Mar 11, 2008 - 10:50 PM
post Mar 12, 2008 - 1:34 PM
maddawg0
Joined Mar 6, '08
From Your moms house
after my friend installed the ebay header i sold him... and detailing the vert here it is, sorta
This post has been edited by maddawg0: Mar 12, 2008 - 1:35 PM
2 Pages V  < 1 2
Lo-Fi Version Time is now: February 19th, 2025 - 11:39 PM
