> wheel bearing seal help!!
post Jul 31, 2007 - 12:31 PM
Daftboy
Joined Jun 30, '06
From West Windsor NJ, USA
OK well I got everything taken apart and brought the hub to a local shop to get pressed they pressed the old one out and the new one in.....they did not press any seals in with it though....Im lost ...I went to go get the seals and they are a rubber seal attached to a metal disc....did these need to be pressed in at the same time as the bearing or do these simply just go on top....I got a kit and it comes with a inner / outter seal and some kind of metal circle thing as well....can someone help me please
post Jul 31, 2007 - 1:42 PM
Daftboy
Joined Jun 30, '06
anyone?
post Aug 1, 2007 - 9:23 AM
LewFX
Joined Jan 28, '05
From Redondo Beach, CA
i think the outer seal goes on the hub and pressed on with the bearing, does this diagram help?
This post has been edited by LewFX: Aug 1, 2007 - 9:24 AM
post Aug 1, 2007 - 6:20 PM
cheeco
Joined Jun 15, '06
From NJ
you can just tap the seals into the knuckle with a plastic hammer. the outer one has to be installed before you press the hub into the bearing. if you dont put the seals in, the bearing will probably fail again.
Lo-Fi Version Time is now: November 25th, 2024 - 11:18 PM
