> help- tapping noise from the transmission?, thought it was valve or rod knock..
post Jul 31, 2007 - 3:57 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
so i came homw from work and parked my car, windows down. i didn't notice the sound(im assuming it wasn't there) but then when i stopped, it came, pretty loud, too. so i thought 'maybe moving makes it less worse?' so i went to put it in reverse, and as soon as i touch the shifter, it went away. i played w/ the shifter more, and i couldn't get the noise to come back. so i flirted w/ the clutch, and it came back. pressed the clutch in, and no noise. let it out, and now its back. try to press the shifter into 3rd w/o pressing in the clutch and the noise was less noticable. why is this coming from my transmission?? Is it even coming from it? is it bad, and how can it be fixed?
post Jul 31, 2007 - 6:50 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
clip.wav - 0.46MB
thats a recording of it. you can hear me shifting through the gears, then letting the clutch out and it comes back..
post Aug 1, 2007 - 1:58 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
noone knows?
post Aug 9, 2007 - 5:18 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
throw out bearing?
post Aug 10, 2007 - 1:38 AM
Harold_Fastwaker
Joined Aug 8, '07
From United States
Sounds like you have a damn gremlin living in your car.
I cant tell what any of those noises are except you reving.
post Aug 14, 2007 - 10:58 PM
soulshadow
Joined Apr 18, '05
From Lincoln, Ar
Yeah sounds like your throwout bearing all right. My was far worse than that when I replaced it.
If its not your bearing than I 2nd the Gremlin.
post Aug 14, 2007 - 11:00 PM
mines been making that noise for about 2yrs now. never caused any problems.
Lo-Fi Version Time is now: February 20th, 2025 - 5:41 AM
