![]() Enthusiast ![]() Joined Oct 31, '03 From Phoenix, Az Currently Offline Reputation: 0 (0%) ![]() |
Hey guys, have had a bit of an issue with my 6gc, a few months back my turn signals stopped working, my hazards work fine so I usually use them to indicate turning but obviously i need to get my blinkers working again. I took it over to my dads place and replaced some fuses and the relay but to no avail. Has anyone had a similar issue or have any idea how to resolve?
Enthusiast Joined Aug 3, '07 From Australia Currently Offline Reputation: 0 (0%) ![]() |
QUOTE(jussten @ Aug 1, 2007 - 12:59 AM) [snapback]584279[/snapback] Hey guys, have had a bit of an issue with my 6gc, a few months back my turn signals stopped working, my hazards work fine so I usually use them to indicate turning but obviously i need to get my blinkers working again. I took it over to my dads place and replaced some fuses and the relay but to no avail. Has anyone had a similar issue or have any idea how to resolve? Yeah I had the same problem, and I'm going to assume you recently pulled the center console out (to replace stereo perhaps?) since that was what happened to me and I fixed it purely by unplugging the hazard lights button and plugging it firmly back in again... Hope that works for you!!! ![]() |
QUOTE(Mabthera @ Aug 4, 2007 - 4:45 AM) [snapback]585120[/snapback] QUOTE(jussten @ Aug 1, 2007 - 12:59 AM) [snapback]584279[/snapback] Hey guys, have had a bit of an issue with my 6gc, a few months back my turn signals stopped working, my hazards work fine so I usually use them to indicate turning but obviously i need to get my blinkers working again. I took it over to my dads place and replaced some fuses and the relay but to no avail. Has anyone had a similar issue or have any idea how to resolve? Yeah I had the same problem, and I'm going to assume you recently pulled the center console out (to replace stereo perhaps?) since that was what happened to me and I fixed it purely by unplugging the hazard lights button and plugging it firmly back in again... Hope that works for you!!! ![]() I didn't pull it out any time recently but I'll check that out and see if it does the trick. |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 9, '05 From Oakland, Cali Currently Offline Reputation: 46 (100%) ![]() |
did u pull out teh dimmer switch?.....
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Nov 7, '06 From Lawrence IN, 46226 Currently Offline Reputation: 17 (100%) ![]() |
if the hazzards work, then that plug is in. it would have to be the dimmer switch i would think.
Lo-Fi Version | Time is now: February 22nd, 2025 - 3:46 PM |
