> NeW LocatioN fOr CaR aMPLIFIEr?, Need Help For Mounting My Amp In A Different Place
post Aug 1, 2007 - 3:48 AM
MauiBuilt
Joined Nov 22, '06
From Maui, HAWAII
I've always had my power amp under my drivers seat-I am now installing a bigger/longer amp.Any suggestions? I was thinking about mounting on the back of the back seats (I have a coupe) or maybe upside down under the rear dashboard. Do you think that any of these can support the weight (15lbs).
post Aug 1, 2007 - 9:38 AM
95CelicaST
Joined Feb 5, '05
From pineapple under the sea
I don't know how heavy the amp that Coomer mounted, but in the Yelli Celi the amp is mounted beneath the rear deck.
**** Photobucket
post Aug 8, 2007 - 8:36 AM
creis
Joined Jan 10, '04
From Shoreline, WA
in a coupe i'm sure you could bult it up under the rear deck with no issues (not plastic but the metel support) as long as your bulting it to the mettle, friend of mine had a zx2, we maid a big fiberglass sub box with an 12" eclipse sub and bulted it to the rear deck support (over 35 lbs, used 4 big bults and 2" washers.) turned out to be incredibly bad looking but held it good.
I would consider in the spare tire space, to the back seats, or if you want to make it more custom, rase the trunk floor a few inches and mount it on the floor, little more work but basicly you just have to make a simple frame and cover so the trunk carpet is lifted up, then mount the amp(s) to the metel floor. inside the frame.
edit: one day i want to learn to spell right the first time.
This post has been edited by creis: Aug 8, 2007 - 8:38 AM
Lo-Fi Version Time is now: December 4th, 2024 - 3:36 PM
