> momo steering wheel on import st205, indicators will not cancel????
post Aug 2, 2007 - 3:04 AM
ianb
Joined May 6, '04
From Liverpool,UK
Hi there guys,
i,ve rercently fitted a genuine momo steering wheel along with the correct momo boss kit on my jap import st205....the wheel looks and works fine but i now have a rather biggish gap around the boss/dash...and also my indicators fail to cancel out when i turn full lock.....i,ve spoken to momo and they reckon it,s normal because of the car being non uk and import model...apparently uk spec gt4,s are fine with same wheel etc??..anyone out there had similar problems?......is it something that can be fixed or do i just take it thats price to pay for owning import model!......thanks Guys any help appreciated.
Ian
post Aug 2, 2007 - 4:30 AM
vsideboy
Joined Mar 29, '06
From Hull, UK
I've got an import GT & GT4 and they both have aftermarket steering wheel bosses but the indicators cancel fine mate.
By the gap I assume you mean the gap in the steering column housing? The GT also has a large gap between this housing and the boss, but the boss thats on the GT4 came with a collar that slides over the top and makes it wider, which hides the gap. Don't know if you can get them for momo bosses though.
All I can think is if you wanted to get a bit of black plastic and make it a similar shape to the front of the housing but with a smaller hole cut in it so it masks the gap?
As for the indicators, I think there should be something sticking out that knocks the indicator off as it passes (can't say for definite though as I've not taken one off before) Maybe theres something on your original one that should be put on before the new boss?
post Aug 2, 2007 - 5:54 AM
lubu
Joined Apr 2, '07
From Great Western Plateau
i got this problem b4 at first i thought its a wheel alignment..took me the whole day a re-align but didnt work also..anyway its rather simple.
take off ur steering wheel & hub... you will see the indicator cancellor (its the white round thing, try to turn the signal and u will see.) and realignment it to the middle then put on ur hub and steering wheel
This post has been edited by lubu: Aug 2, 2007 - 5:56 AM
98% completion
aaRon
post Aug 2, 2007 - 6:36 AM
ianb
Joined May 6, '04
From Liverpool,UK
QUOTE(lubu @ Aug 2, 2007 - 11:54 AM) [snapback]584602[/snapback]
Everything is alligned correctly all the grooves in the correct slots etc.....when the wheel and boss are removed i can switch on indicators then manually turn the collar with my hand to cancel the indication...just when the wheel and boss kit are on the car and are in as far as possible and as i say married up correctly it will not cancel inds........momo uk say its common problem with import gt4 using their bosses but i,m just getting other peoples ideas on the topic and to see if similar probs have arisen with momo wheels or similar....thanks
post Aug 2, 2007 - 6:46 AM
lubu
Joined Apr 2, '07
hrms..i wouldnt think so..my friend has an gt4 and his works fine.
im not taking abt the grooves in the correct slot im talking abt the cancel dail or what ever you call it..its the white turnable thing that sits around the steering rod, when you turn the indicator and turn the wheel the indicator get cancelled if the dail sits in the correct spot otherwise you have to turn another half turn or so to cancel it..
This post has been edited by lubu: Aug 2, 2007 - 6:47 AM
98% completion
aaRon
post Aug 2, 2007 - 7:53 AM
jesterwr217
Joined Feb 27, '07
From cape coral/ft myers florida
i have a spearco wheel and it does the same thing i just deal with it lol
BOOST GETS YOU LAID!!!!
post Aug 2, 2007 - 8:11 AM
vsideboy
Joined Mar 29, '06
From Hull, UK
QUOTE(ianb @ Aug 2, 2007 - 12:36 PM) [snapback]584607[/snapback]
Like I said, I ain't got a problem with either import GT or GT4. I've got 2 different bosses and they both work fine.
Send the momo boss back and get someone elses.
Lo-Fi Version Time is now: February 22nd, 2025 - 8:53 AM
