lots of New problem questions, plugs/pcv/tires/sri |
Aug 2, 2007 - 10:28 AM |
Enthusiast Joined Aug 15, '06 From MICHIGAN Currently Offline Reputation: 1 (100%) |
Will this Distributor cap work? click
How about this PCV valve, and how hard are they to replace? click Thanks for the help This post has been edited by aslearvert: Aug 18, 2007 - 2:10 PM |
Aug 2, 2007 - 11:34 AM |
Enthusiast Joined Jul 2, '05 From NYC Currently Offline Reputation: 0 (0%) |
i can't comment if the cap will fit or not being that i'm not the seller. As for the pvc valve it is very simple to remove and install, there is no trick to it.
i suggest changing the distributor rotor along with the cap (i assume youre changing out your spark wires and plugs as well). |
Aug 2, 2007 - 1:20 PM |
Ok, thanks. The pcv valve is on its way, and so are a set of NGK plugs. I will get wires soon.
I'm still wondering about the cap though... Also, is the fuel filter in a pretty easy location to change? This post has been edited by aslearvert: Aug 2, 2007 - 1:36 PM |
Aug 3, 2007 - 12:54 AM |
Enthusiast Joined Feb 3, '06 From Czech Republic (Europe) Currently Offline Reputation: 56 (100%) |
just one silly question:
Are you sure this Bosch aftermarket piece is better than stock Denso one? -------------------- No more replicas... This is evolution... This is SS-four :)
________[Featured Celica of 6gc.net @ 2010]_________ |
Aug 3, 2007 - 7:18 AM |
QUOTE(malpaso @ Aug 3, 2007 - 12:54 AM) [snapback]584884[/snapback] just one silly question: Are you sure this Bosch aftermarket piece is better than stock Denso one? I have no idea. haha But the nearest toyota dealership is about 30 miles away (maybe more) so its more of a pain to go there, than to buy something off the internet. I've never gotten anything from the dealership. |
Aug 3, 2007 - 7:29 AM |
QUOTE(aslearvert @ Aug 3, 2007 - 2:18 PM) [snapback]584922[/snapback] QUOTE(malpaso @ Aug 3, 2007 - 12:54 AM) [snapback]584884[/snapback] just one silly question: Are you sure this Bosch aftermarket piece is better than stock Denso one? I have no idea. haha But the nearest toyota dealership is about 30 miles away (maybe more) so its more of a pain to go there, than to buy something off the internet. I've never gotten anything from the dealership. www.toyotaworld.com -------------------- No more replicas... This is evolution... This is SS-four :)
Aug 3, 2007 - 7:39 AM |
QUOTE(malpaso @ Aug 3, 2007 - 7:29 AM) [snapback]584925[/snapback] QUOTE(aslearvert @ Aug 3, 2007 - 2:18 PM) [snapback]584922[/snapback] QUOTE(malpaso @ Aug 3, 2007 - 12:54 AM) [snapback]584884[/snapback] just one silly question: Are you sure this Bosch aftermarket piece is better than stock Denso one? I have no idea. haha But the nearest toyota dealership is about 30 miles away (maybe more) so its more of a pain to go there, than to buy something off the internet. I've never gotten anything from the dealership. www.toyotaworld.com WHOA! Thanks man. I really had no idea that that site existed. SWEET! Do they accept Paypal? Are those prices with shipping included? Hmmm... I'm getting a server error when I go to the site... OooOO and they want a credit card... not good. I dont have one. This post has been edited by aslearvert: Aug 3, 2007 - 8:21 AM |
Aug 18, 2007 - 1:50 PM |
Ok, I have my plugs and pcv valve. I have a couple of new questions though.
1. Is there a "how to" on changing plugs? If not can someone just give me a quick run down? I take the wires off, and a huge tube comes out... whats next? Do you loosen the hex head and take it out after you pull the tube out?haha (Sorry, I've never done this before on my car. ) Everyone has to start somewhere right? haha 2. What are the plugs supposed to be gapped to? Also, I figured since I was asking all these questions, I'd ask more. 4. I hooked up my sri before I was on the site, and I am wondering if I hooked it up correctly now. Can someone tell me if there is a better way of doing this? 5. All of my tires are wearing evenly except, my right rear is bald... why would that be? Do I need an alignment? ^^ Right Front ^^ Right rear (problem tire) sorry about the dirty car... dirt roads suck. Any help is greatly appreciated -Thanks This post has been edited by aslearvert: Aug 18, 2007 - 2:18 PM |
Aug 18, 2007 - 4:53 PM |
Enthusiast Joined Jan 10, '06 From Mozambique, Africa Currently Offline Reputation: 8 (100%) |
^^Camber?
-------------------- "Remember, amateurs built the ark and professionals built the Titanic. But revolutionaries built the Celica!"- Me |
Aug 18, 2007 - 6:50 PM |
Enthusiast Joined Aug 11, '07 From Corona, CA Currently Offline Reputation: 4 (100%) |
to replace your spark plugs
u already got em, **make sure you have anti-seize n dielectric gel** the antiseize will help when u replace the plugs later on so that they dont get stuck. the dielectric gel helps keep moisture out n keep the plug wires healthy. ***Remember to do 1 plug at a time so as not to mix plug wires. If you do take them all out, make sure you tag them to make sure u dont mix them up*** i believe the gap for the 5sfe is 1.1mm..might wanna double check that with an auto shop like autozone or napa to remove the existing plugs, get a matching extended ratchet (if you have one) that matchs up with the plug size. if u dont have a long enuff ratchet you can pick up a spark plug remover for 4 bucks at a autozone. if there is a lot of resistance when removing, try tightening the plug a little to try n break off any buildup that could be causing it to be stuck. dont let anything fall into the hole u jus pulld the spark plug out of okay, u should have the plug out. apply the antiseize n dielectric gel like it says on the respective packages, if u have a spark plug remover, jus stick the new plug n place the plug back in the engine. ***when tightening, be sure not to crossthread! if you cannot rotate the plug easily after a couple turns, continue to loosen slowly so that you feel the plug's threads fall into place n then begin tightening*** repeat for each plug. This post has been edited by xs94st: Aug 18, 2007 - 6:51 PM -------------------- Pandelica 2.0 in progress. |
Aug 19, 2007 - 10:04 AM |
Ok, thank you very much, I'll give it a shot later today.
About the tire problem, I've been asking around and lots of people are telling me that its probably just a bad/defective tire. I have the warranty at discount tire, so I am going to call and see if they will replace it. For the camber thing... Do I just need an alignment, or how do I fix that? Anyways, that leaves the SRI. I have noticed that some people just plug the hole that I have the hose going to. Should I do that too? |
Aug 19, 2007 - 12:49 PM |
America's Tire
There's a link for ya to check out a good tire shop. They usually check your tires for free and if you wanna go take one to them they probably wont charge you anything for letting them check it out. I take my car there all the time, they patch up flats if ur on the go for free, free rotations, free tire check + reinflation, etc. Pretty nice. Check em out or just give em a call! -------------------- Pandelica 2.0 in progress. |
Aug 19, 2007 - 3:01 PM |
Thanks man, I will definitely give them a call.
Aug 19, 2007 - 4:40 PM |
Enthusiast Joined Jun 8, '07 From Houston, Texas Currently Offline Reputation: 1 (100%) |
I don't think you have the right coupler on the SRI. I would go to an auto parts store and look for a coupler that is for the size of your tube to the size of your TB. It looks like that material isnt holding up too well.
Also, I went to lowes and got some single pieces of metal to make a sort of brace for the SRI so it wouldnt be falling down so much. Ill get a pic up later. -------------------- |
Lo-Fi Version | Time is now: November 23rd, 2024 - 2:18 PM |
