2 Pages V  < 1 2
> w/i kit
post Aug 19, 2007 - 11:07 AM
jesterwr217
Joined Feb 27, '07
From cape coral/ft myers florida
o and a warning to some the kit clearly states just because u can run more boost and more timming dont because then your in the same postion you were before and ull still have the same problems like knock wink.gif
BOOST GETS YOU LAID!!!!
post Aug 19, 2007 - 11:22 AM
QUOTE(Driveby @ Aug 19, 2007 - 6:27 AM) [snapback]589077[/snapback]
Ive just bought the 150 PSI Stage 2 Digital Progressively Controlled Kit from enginerunup.com for my faff, hoping to fit it next week though ve ordered some Aquamist jets and check valves as the supplied checkvalve assembly is just plain big ass ugly. The kit will be interfaced with an Aquamist DDS3 for monitoring purposes.
What boost pressure are you guys triggering at? Im looking to start at 12psi ~ 50% upto 18psi+ ~ 100% running 50/50 methanol/water.
Id love to get my pump mounted in the engine bay and use the stock washer bottle assembly as my reservoir and add a small bottle for my screen wash as trunk space is already limited on the GT4 and I have my battery in there also.
i have mine set to come on at about 10psi. progressive controllers are cool and all, but youll probably want it to spray 100% asap. because if you think about it, boost builds quickly, and the sooner you start flowing 100%, the more cooling you will get.
QUOTE(jesterwr217 @ Aug 19, 2007 - 12:07 PM) [snapback]589110[/snapback]
yeah, for your setup, i would keep the boost were youve always had it. the WI will help combat the advance timing, and high compression of your NA motor. so it should run better and have more power, on its own, just by adding the kit.
QUOTE(jesterwr217 @ Aug 19, 2007 - 11:47 AM) [snapback]589107[/snapback]
QUOTE(CaliJeff @ Aug 19, 2007 - 11:44 AM) [snapback]589105[/snapback]
let us know if that sprayer nozzle falls out that way. Not saying it will, just that many of us here are unsure of the best way to put it.
as long as u seal it with high temp silicone it shouldnt fall out
silicone wont hold it in place, and it might clog the jet. your supposed to drill and tap the piping so that the nozzle threads right into it... but i guess that might be hard to do, if you have thin gauge piping. just make sure its nice and tight, cause if the the nozzle falls off, it will kill your motor.
post Aug 19, 2007 - 11:38 AM
jesterwr217
Joined Feb 27, '07
yea i drilled and tapped it just did a lil silicone on the outside side of the piping as insurace lol
This post has been edited by jesterwr217: Aug 19, 2007 - 11:38 AM
post Aug 19, 2007 - 11:41 AM
what size nozzle did you go with ?
post Aug 19, 2007 - 12:42 PM
jesterwr217
Joined Feb 27, '07
honestly idk the kit came with 3 and i used the smallest one i may go up in size later on
post Aug 22, 2007 - 6:12 PM
toyotacrazy
Joined Mar 4, '06
From Ohio
QUOTE(jesterwr217 @ Aug 19, 2007 - 11:38 AM) [snapback]589115[/snapback]
I tapped into my intercooler piping then used red threadlocker to make sure it didnt wiggle loose.
2 Pages V  < 1 2
Lo-Fi Version Time is now: February 22nd, 2025 - 5:26 AM
