VIS Carbon Fiber Trunk |
Aug 6, 2007 - 7:35 PM |
Enthusiast Joined Jan 14, '06 From New York Currently Offline Reputation: 0 (0%) |
Does anyone here have the VIS carbon fiber trunk and if so how hard was it to install/easy and were you able to mount back the rear wiper and have your heat sensors working???
Thanks! -------------------- I drive a Celica. Anything "less" is just a car! |
Aug 6, 2007 - 7:38 PM |
fitment is stock, but you will not have a rear wiper or spoiler. I can't remember if the 3rd brake light is lost, but the heat sensors will work, as your wiring will be brought through into the new hatch, and you will need to have the glass pulled from the stock one and installed in the new one.
Aug 6, 2007 - 8:01 PM |
Will I be able to drill the carbon fiber hatch to mount an aftermarket wing?
___________________________________________________ QUOTE(95CelicaST @ Aug 6, 2007 - 7:38 PM) [snapback]585863[/snapback] fitment is stock, but you will not have a rear wiper or spoiler. I can't remember if the 3rd brake light is lost, but the heat sensors will work, as your wiring will be brought through into the new hatch, and you will need to have the glass pulled from the stock one and installed in the new one. -------------------- I drive a Celica. Anything "less" is just a car! |
Aug 6, 2007 - 8:11 PM |
You could drill it, but if not properly reinforced the stress of the wing will destroy the hatch.
Aug 6, 2007 - 8:13 PM |
Enthusiast Joined Jul 2, '05 From NYC Currently Offline Reputation: 0 (0%) |
the hatch fits pretty well and the cf knits are tight and nicely patterned. like mentioned, you loose the wipers but not the 3rd brake light. you can also hook up the defrost but i opted not to since i don't really drive the car.
as for the interior plastic pieces, you will need to dremel out the pre-patterned outlines for the interior clips. i suggest doing this before installing the hatch since it makes the process easier and faster. here are some pics of my hatch... |
Aug 6, 2007 - 8:16 PM |
QUOTE(nemesis @ Aug 6, 2007 - 9:01 PM) [snapback]585873[/snapback] Will I be able to drill the carbon fiber hatch to mount an aftermarket wing? ___________________________________________________ QUOTE(95CelicaST @ Aug 6, 2007 - 7:38 PM) [snapback]585863[/snapback] fitment is stock, but you will not have a rear wiper or spoiler. I can't remember if the 3rd brake light is lost, but the heat sensors will work, as your wiring will be brought through into the new hatch, and you will need to have the glass pulled from the stock one and installed in the new one. the hatch comes with pre-drilled holes for the wing bolts. all you have to do it enlarge the pre-drilled holes and use largers washers with a metal bracket that connects the three bolts, in others words make a metal plate per side. |
Aug 6, 2007 - 8:17 PM |
Nice, RCTCelica! Nice work! Really neat! Another member mentioned about reinforcing the wing! How so?
___________________________________________________________________________ QUOTE(RCTCelica @ Aug 6, 2007 - 8:13 PM) [snapback]585877[/snapback] the hatch fits pretty well and the cf knits are tight and nicely patterned. like mentioned, you loose the wipers but not the 3rd brake light. you can also hook up the defrost but i opted not to since i don't really drive the car. as for the interior plastic pieces, you will need to dremel out the pre-patterned outlines for the interior clips. i suggest doing this before installing the hatch since it makes the process easier and faster. here are some pics of my hatch... -------------------- I drive a Celica. Anything "less" is just a car! |
Aug 6, 2007 - 8:29 PM |
If yours came with holes pre-drilled it is something that was done afterwards.
Read and look http://www.6gc.net/forums/index.php?showtopic=29633&hl= -------------------- 1991 MR2 - T-tops - Crimson Red - Gen3 3SGTE - Lots of money
Aug 6, 2007 - 8:42 PM |
95CelicaST, thanks for your help! I would also like to know if the trunk needs to be reinforced like the carbon fiber hood because of its light weight?
____________________________________________________ -------------------- I drive a Celica. Anything "less" is just a car! |
Lo-Fi Version | Time is now: November 28th, 2024 - 3:33 AM |
