> Painting Rims Question? (Please Help), Calling Experienced Wheel Painters.
post Aug 7, 2007 - 10:38 AM
94celigts
Joined Jun 13, '07
From Whitby, ON, CAN
Ok i began stripping/sanding and prepping my rims for paint on the weekend.
The first rim i painted went perfect looks great and everything. After this one though it all went bad.
It was hot out it could possibly be that? but what would happen is this, i primed the rim with normal primer, used a bit of cleaner to get rid of any dust/dirt from the rim then waited a bit and painted with Flat black Duplicolour rim paint. it started out alright but then i got alot of fisheyes, little circles/ bubbles in the paint. I dont know why this happend but it did so i tried to do it to the next rim, same thing again. It is really making me angry and fed up lol, Please could someone let me know if this has happend to them or if there is a way to fix it.
Like i said it was just under 30 degrees outside and i was not doing it in direct sunlight could that be a factor?
As well i did Prime then paint the rims, Do you need to prime with Duplicolour wheel paint.
finally the cleaner i used is acetone.(sp) i dont know but could that be doing something with the paint?
Please let me know
Thanks for your input
As well any suggestions with a way to try to make it work better?
Dana
This post has been edited by 94celigts: Aug 8, 2007 - 8:35 AM
post Aug 8, 2007 - 5:38 AM
soven
Joined Mar 14, '05
From Auckland,New Zealand
not cleaned properly from the sound of things.
post Aug 8, 2007 - 8:49 AM
FortuneCookie
Joined Dec 12, '06
From Fob Sharana, Afghanistan
I have painted rims on and ofcourse did it myself. Read the label on those canisters on what degrees temp it's best used it. I remember mine did that becuz it was extremely hot outside. The best time to actually do it is when it's cold outside.
post Aug 8, 2007 - 9:01 AM
a) remember he's canada i think he means 30* C
b) you gotta make sure you wipe down really well with the acetone, and make sure there isn't acetone "left" on the surface (after all paint can't work well with such material) so make sure you use a clean lint free cloth to wipe down and make sure its dry dry
c) THIN LIGHT COTES the first time you go over it you still wana be able to see some primer through it. EVEN smooth strokes of the paint can
post Aug 8, 2007 - 9:05 AM
94celigts
Joined Jun 13, '07
i strip/sand/acetone it?
I Prime it?
I acetone it again. after primer??? wont this remove all the primer, or do i do it lightly just to take little stuff off??
Then i go ahead with paint. let me know thanks
post Aug 8, 2007 - 9:11 AM
no don't acetone it after primer
after primer gets a chance to dry, wet sand it lightly with high grit sand paper
rinse with water, dry, wipe down with a TACK CLOTH
post Aug 8, 2007 - 10:43 AM
Jlacker3
Joined Jul 3, '07
From Texas
Is it possible to get your wheels chrome dipped? Mine are just a flat gray and I'd really like them chrome. Price?
Thanks
Lo-Fi Version Time is now: November 30th, 2024 - 11:09 PM
