> Fuel Gauge Problem
post Aug 8, 2007 - 2:51 AM
3SGTE
Joined Jun 13, '07
From U.K
The other day out driving i noticed after a good few miles, (using some good boost) the fuel gauge stopped moving at half a tank.... Then the fuel light came on a while after. So i put gas in and the gauge went a little higher, but not much. (I guess this means that the fuse must be ok if the gauge moved at all)
So guys, any ideas what the problem might be??
post Aug 8, 2007 - 12:32 PM
Redline08
Joined Feb 23, '07
From Albany, NY
its old, happens to all gas gauges after a while, mines so far off i dont even bother checking it, i just wait till the light comes on. You can get aftermarket ones if your in dire need of it but if i was you id just wait for the light lol
post Aug 8, 2007 - 1:34 PM
3SGTE
Joined Jun 13, '07
From U.K
Thanks Redline08, but im the type of guy who hates it when simple stuff goes wrong, i gotta fix it... Any ideas how to fix or should i just take it to a garage??
post Aug 8, 2007 - 1:46 PM
Stu37363
Joined Jun 30, '05
From Chattanooga, TN
did you install after market gauge faces? sometimes when its hot they can come loose and stop the needle from moving.
post Aug 8, 2007 - 2:20 PM
3SGTE
Joined Jun 13, '07
From U.K
QUOTE(Stu37363 @ Aug 8, 2007 - 7:46 PM) [snapback]586385[/snapback]
No just standard gauges! Any ideas Stu? Was working fine then just stopped on a journey the other day
post Aug 8, 2007 - 7:04 PM
celicamike
Joined Dec 26, '05
From So Cal
the needle could be hung up on something, just move the needle up and down to see if its free, you could also pop the needle off then put it back on.
post Aug 8, 2007 - 7:58 PM
94coupe
Joined Jun 25, '06
From South Boston, VA
could be the float sticking on the fuel sending unit located on the fuel pump assembly in the tank
post Aug 8, 2007 - 8:09 PM
Redline08
Joined Feb 23, '07
From Albany, NY
let me know how ripping into your gas tank goes...
lmao
post Aug 9, 2007 - 8:49 AM
Stu37363
Joined Jun 30, '05
does anyone know how the low fuel light gets its signal? i would have assumed it was from the same source as the needle. i dont see how the fuel level senser in the tank could mess up and you still get the low fuel light.
if it is the actual fuel gauge... you can pick up another gauge cluster at a junk yard. the fuel and engine temp part of the cluster can be removed and swapped without messing with the speed/odometer part.
This post has been edited by Stu37363: Aug 9, 2007 - 8:52 AM
post Aug 9, 2007 - 11:27 AM
goferris
Joined Feb 14, '07
From Provo, UT USA
QUOTE(Stu37363 @ Aug 9, 2007 - 7:49 AM) [snapback]586613[/snapback]
the thing is since he has a gt4 that part of his gauge is diff then ours cuz that is also where the boost gauge is. parts will be a lot harder to find since it would have to come out of a gt4 as well. that is quite a predicament you have there
i am the same way. little things like that annoy the hell outta me. my car has a few little things that don't work that just piss me off sometimes.
post Aug 10, 2007 - 10:43 PM
duders
Joined Jun 13, '07
From Miami Beach, FL
Yeah, the same thing happened to me. Only thing is when I installed my new bulbs on my gauge the gas gauge just stays all the way on the bottom even after putting 25.00 worth of gas. It's worrying me alot. I don't want to just run out of gas somewhere someday. Guess I should start saving up for a new gauge...
post Aug 21, 2007 - 3:30 AM
3SGTE
Joined Jun 13, '07
From U.K
after a rew days of close observation, i filled the tank with gas and only when it gets down to half a tank, the needle stops moving!!! Does that make any difference??
post Aug 22, 2007 - 1:55 AM
duders
Joined Jun 13, '07
No clue dude. Like a question, How much does it cost to fill up the Celicas gas tank up? 40? I need to know
post Mar 21, 2011 - 6:58 PM
whatthe
Joined Aug 13, '08
From Australia
I dont want to start a new thread. But as of yesterday, my low fuel light dont turn off. The guage works fine, but the light stays on constantly =\
post Aug 2, 2011 - 7:46 PM
nammer
Joined Aug 22, '07
From Burnaby, British Columbia, Canada
I have a similar problem where my fuel gauge says i'm empty with no empty light on but I know for sure I have more than half a tank left. Is there another way to fix it other then getting a new cluster (or that section of the cluster)? I too have a JDM cluster.
What exactly is "broken"? Can I take it out and adjust something?
post Aug 5, 2011 - 6:40 PM
nammer
Joined Aug 22, '07
anyone have any tips?
post Aug 7, 2011 - 4:54 AM
Galcobar
Joined Mar 3, '05
From Richmond, B.C.
Gas pump with the two sender units (one operates the idiot light, the other operates the level gauge) is easily accessible. Pull rear seat bench, remove highly visible covers.
Simplest fix -- buy a replacement sender unit and, well, replace.
post Aug 7, 2011 - 1:00 PM
toyotatech3
Joined Jul 30, '04
From colorado
F10 FUEL SENDER
1-2 : APPROX. 3 ohms AT FUEL FULL
APPROX. 110 ohms AT FUEL EMPTY
remove rear seat and access panel, unplug sender, with fuel tank full or close to empty check resistance. if its ok replace guage. or get a resistor around 50 ohms put it in pin 2 (i think) and ground it, you should end up with about half tank reading on guage, if not replace it.
post Aug 12, 2011 - 7:26 PM
nammer
Joined Aug 22, '07
QUOTE (Galcobar @ Aug 7, 2011 - 2:54 AM) *
Thanks! Do you happen to know the part number for a sender unit for the st205?
QUOTE (toyotatech3 @ Aug 7, 2011 - 11:00 AM) *
F10 FUEL SENDER
Thanks! I will try this in a few days and post again if I run into any problems
Lo-Fi Version Time is now: November 28th, 2024 - 3:08 AM
