wide wheels/tires rubbing ... |
Aug 9, 2007 - 12:23 PM |
just wanted to get some ideas on what people have done to eliminate the rubbing in the rear when using wide rims/tires or spacers. i have 17x7.5 45 offset rims with 15mm spacers. as soon as i put them on, the rears would rub like crazy on the inner lip of the rear fender. i cut slits into that lip and used vice grips to bend the lip up. this helped a lot and got rid of most of the rubbing, however it still does rub ever once in a while. any ideas?
Aug 9, 2007 - 12:38 PM |
Enthusiast Joined Aug 8, '07 From United States Currently Offline Reputation: 4 (100%) |
Rubber mallet to knock the inner liner up higher and flatten out the slits that you previously cut.
This post has been edited by Harold_Fastwaker: Aug 9, 2007 - 12:38 PM -------------------- |
Aug 9, 2007 - 12:51 PM |
Replace the 15mm spacer with a 10mm spacer?
Aug 9, 2007 - 1:50 PM |
QUOTE(Harold_Fastwaker @ Aug 9, 2007 - 1:38 PM) [snapback]586653[/snapback] Rubber mallet to knock the inner liner up higher and flatten out the slits that you previously cut. pretty much did that with the vice grips already. -------------------- 15PSI - 30MPG - Megasquirt Tuned
Aug 9, 2007 - 2:30 PM |
Enthusiast Joined May 3, '04 From pittsburgh Currently Offline Reputation: 0 (0%) |
lower offset..tehehe
-------------------- Now SR powered |
Aug 9, 2007 - 2:40 PM |
what about fender rolling. has anyone tried it on our cars?
Aug 9, 2007 - 2:48 PM |
Enthusiast Joined Jun 13, '05 From Poughkeepsie, NY Currently Offline Reputation: 2 (100%) |
so your offset is 30 art?
what size tires are on your rims? 225-45-17? -------------------- Kawi Love |
Aug 9, 2007 - 2:57 PM |
17x7.5 45 offset rims with 15mm spacers and 225-45-17 tires
Aug 9, 2007 - 3:10 PM |
so u have a total offset of 30 with 225s
that why your rubing my rims were 17x8 with 225-45-17 with a 35mm offset....and i coudlnt get my fingers between the tires and the fender...ive never seen rolled fenders on a celica, u can give it a shot art. cant be TERRIBLE. another solution is sell the 15mm spacers, and get 10mm ones to replace them edit: idk but heres ebay ones: http://cgi.ebay.com/ebaymotors/PAIR-7mm-WH...1QQcmdZViewItem 7mm off set This post has been edited by devilsden97: Aug 9, 2007 - 3:21 PM -------------------- Kawi Love |
Aug 9, 2007 - 3:20 PM |
my offset might be 30, but the rim width is only 7.5in. so i thought i might be able to get away with it.
Aug 9, 2007 - 3:28 PM |
IIRC the smaller your offset, the smaller your offset, the farther out the wheels sit...
i understand yours are 7.5 and mine were 8" wide, but 5mm = .1969" so...idk, cuz now this makes no sense to me. i say: 1) try to roll teh fenders, if that doesnt work 2) smaller spacers, that dont work 3) spacers and rolled fenders better....or else -------------------- Kawi Love |
Aug 9, 2007 - 3:32 PM |
Enthusiast Joined Feb 27, '07 From cape coral/ft myers florida Currently Offline Reputation: 7 (100%) |
my front and rear have been rolled
-------------------- BOOST GETS YOU LAID!!!! |
Aug 9, 2007 - 3:36 PM |
^photos!
Aug 9, 2007 - 7:11 PM |
Enthusiast Joined Jun 14, '05 Currently Offline Reputation: 1 (100%) |
bring out the baseball bat!
Aug 9, 2007 - 7:42 PM |
QUOTE(jesterwr217 @ Aug 9, 2007 - 4:32 PM) [snapback]586709[/snapback] my front and rear have been rolled can you post some close up pics? did they have any issues with doing the rear? -------------------- 15PSI - 30MPG - Megasquirt Tuned
Aug 10, 2007 - 12:16 AM |
QUOTE(lagos @ Aug 9, 2007 - 8:42 PM) [snapback]586754[/snapback] QUOTE(jesterwr217 @ Aug 9, 2007 - 4:32 PM) [snapback]586709[/snapback] my front and rear have been rolled can you post some close up pics? did they have any issues with doing the rear? ill try to get some close up pics when i can but as far as i kno no the bodywork was all done while i was on a cruise lol so i wasnt there to see it first hand -------------------- BOOST GETS YOU LAID!!!! |
Aug 10, 2007 - 12:37 PM |
Wrap a towel around a bat and jack up the car enough to get the bat between the tire and fender lip... lower the jack little by little while pushing the lip up inside the wheel well and continue to work your way around. Its easy and works fine. You will probably have to touch up alittle cause the paint may crack some if its not hot enough.
Aug 12, 2007 - 11:40 AM |
You could always try 1. buying camber plates and adjusting the camber, or 2. Stretching 215's or dare I even say 205's on your wheels, but rolling the fenders is your best bet
Aug 12, 2007 - 12:21 PM |
Enthusiast Joined Mar 17, '05 From The Netherlands Currently Offline Reputation: 0 (0%) |
I had the same problem.
I have 225/40/18 GoodYear Eagle F1, my current offsett in the back is 28 (Rim = 48 +20mm spacer) Since I knew the paint would crack if not properly heated I went to the bodyshop department of my local Toyota Dealer (the one in charge there was the former owner of my car ) I let them grind down about 4-5mm of metal and resprayed with black+clear, everything is fine since. It only rubbed on about 1-2mm at most tho. DONT, really DONT grind/cut away further then the spotwelds since it hold 2 different parts together. BTW tyre brand does matter here, my Toyo's are nowhere near the width of the Goodyear even tho its the same width, the Goodyear's are about 1-1,5 cm wider then my Toyo's. Which caused the rubbing. EDIT I looked at your photo's, and you car is really low in the back (compared to mine anyways) Because of this you probably have to roll/cut/grind a lot more then I had to do. This post has been edited by Kadett: Aug 12, 2007 - 12:25 PM -------------------- JDM Powerplant installed, BPU coming very soon!
Aug 12, 2007 - 12:44 PM |
yeah i think ride height and suspension has a lot to do with my issue too. hopefully jester will come through with the pics, so i can see how it looks rolled.
Lo-Fi Version | Time is now: November 29th, 2024 - 11:25 PM |
