> Engine treatment., what does everybody use
post Aug 4, 2003 - 10:28 PM
FallenHero
Joined Dec 26, '02
From Alabama
Ok, I just turned 100k miles and my engine seems kinda funny feeling. (probably in my head) Also, it doesn't seem to shift like it used to. What engine treatment is the best, and is there anything else you people would do?
Jon
post Aug 4, 2003 - 10:42 PM
GeEkBoY
Joined May 17, '03
From Ontario, Canada
They are mostly garbage and cause more damage then they solve. If you are concerned about your engine, use synthetic oil. Synthetic trans fluid may help the shifts as well otherwise just change the fluid and filter in the trans.
post Aug 5, 2003 - 3:19 AM
Stipt
Joined Apr 29, '03
From Davenport, IA
Ummm.....advice, check your water pump and make sure its l33t. Cuz mine just blew up on me, sparyed anti-freeze on my timing belts and now I'm looin' at 700 to shell out frown.gif I would check your engine, only costs like 30 bucks around here. I was at 105k miles. Best thing, get your engine inspected LoL!
post Aug 5, 2003 - 2:35 PM
ghostdog
From ny to philly
my waterpump blew at ~100k too. thankfully I was able to combine the ud pulley install with it so overall cost wasn't bad.
post Aug 5, 2003 - 8:19 PM
FallenHero
Joined Dec 26, '02
From Alabama
Aren't they supposed to be re-tuned at 100k also? Whould toyota be able to inspect it? I wonder what a water pump for a 7a costs?
Jon
post Aug 5, 2003 - 10:48 PM
Milds3vn
Joined Feb 11, '03
From Phila, PA
YO!!! GO synthetic no kidding, you will fell a big difference!!!!!!!!!!!!!!!!!!!
post Aug 9, 2003 - 5:42 PM
Jussimple
Joined Jan 3, '03
From South Carolina
Well, I used the zmax additive and I noticed a deference in responsiveness and in engine idle( I maintain my ride pretty well). I've been putting it in ever since. I treat the engine every two oil changes. My car has been running like a new car ever since. My $.02 rolleyes.gif
J
This post has been edited by Jussimple: Aug 9, 2003 - 5:42 PM
post Aug 9, 2003 - 7:26 PM
Cody
Joined Dec 11, '02
From Sioux Falls, SD, USA
Heh, but Zmax is apparently getting sued by the government...
post Aug 9, 2003 - 7:50 PM
Jussimple
Joined Jan 3, '03
From South Carolina
For what?????
J
Lo-Fi Version Time is now: February 24th, 2025 - 6:27 PM
