> 3S Swappers, Air Conditioning
post Aug 10, 2007 - 1:28 AM
yyet
Joined Jan 6, '06
From Oahu, Hawaii
I had a quick question for all the 3S swappers... I wanted to do a swap too, but was just wondering if you guys have air conditioning in your 3S? B/c i always drive with the AC on, so i was just wondering if the 3s motor has AC b/c i didn't read anything about that before and my friends who did like k20 and sr20 swaps don't have ac.
Wyatt
post Aug 10, 2007 - 1:54 AM
Defgeph
Joined Apr 17, '03
From Rockland NY
You have a GT, I believe you can use your stock AC unit and bolt it right up to the 3S. You just need to have the wiring hooked up for it.
I will return one day.
post Aug 10, 2007 - 5:28 AM
zipstrips
Joined Sep 9, '02
From Scranton, Pa
im still working on getting mine hooked up. need to bolt upthe lines and charge the system... supposedly the wireing was done to keep it
post Aug 10, 2007 - 8:21 AM
2slow2nervous
Joined Aug 25, '06
From HAMILTON NJ
i need to get my lines ran also i dont have ac as of rite now.
post Aug 10, 2007 - 10:16 AM
i have fully working AC, with the AC idle up system and everything. boost+ac=awesome.
post Aug 10, 2007 - 10:25 PM
yyet
Joined Jan 6, '06
From Oahu, Hawaii
Okay cool... so most of you took the ac from the stock motor and bolted right up.
Wyatt
post Aug 10, 2007 - 10:43 PM
toyotacrazy
Joined Mar 4, '06
From Ohio
My a/c works fine. Im using the 5s-fe compressor. My a/c idle up isnt hooked up though.
post Aug 12, 2007 - 1:16 PM
95celgt
Joined Oct 5, '03
From South TX.
i installed mine a few weeks ago but I had to wire up the compressor to a switch because when the pressure switch would send 12V to the compressor it would make my engine die, but it works now, i just turn it off when im gonna go over 3500 rpm and run the car..
post Aug 12, 2007 - 1:23 PM
QUOTE(95celgt @ Aug 12, 2007 - 2:16 PM) [snapback]587402[/snapback]
thats cause you dont have the idle up system.
hardwiring it to a switch will burn up your ac comp, because the system needs to cycle on/off ever few sec on its own.
post Aug 15, 2007 - 3:09 PM
115celi
Joined May 11, '06
From Wisconsin
Do you need to replace the AC compressor or can you use the one on the 3s? What would I need to do to get it to work with an ST?
post Aug 15, 2007 - 3:35 PM
Dr_Tweak
Joined Mar 31, '04
From Summerville, SC
QUOTE(115celi @ Aug 15, 2007 - 8:09 PM) [snapback]588213[/snapback]
For an ST, you're going to need to use the 3SGTE compressor and then have some custom lines made. If you have the ST lines and at least part of the lines of the 3SGTE, a good tig-weldor can weld them together for you.
-Doc
Click here to see my swaps
drtweak@phoenixtuning.com
post Aug 24, 2007 - 8:37 PM
zipstrips
Joined Sep 9, '02
From Scranton, Pa
QUOTE(Dr_Tweak @ Aug 15, 2007 - 1:35 PM) [snapback]588219[/snapback]
-Doc
gt 5sfe lines should bolt up. i have them and they looked good,,guess ill have to get it on there to say for sure.
post Aug 30, 2007 - 10:07 PM
3rdgen3SGTE
Joined Nov 21, '05
From Quebec
I remove all of that today...a/c radiator location is nice place to put my intercooler rad
I need to do many try to find 40 inch strap for alternator
Celica GTS turbo 1994
3sgte genIII Ct20b
Lo-Fi Version Time is now: February 20th, 2025 - 10:42 AM
