> Boost Gauge Gets Extremely HOT, Is this normal?
post Aug 12, 2007 - 12:36 PM
JoKeRkId613
Joined Apr 25, '03
From Miami, FL
So I just installed a black TRD boost gauge - looks sooo sexy. I love it, but holy crap it gets hot... as in heat-hot. I'm pretty sure I wired everything correctly, but when I touch the bezel or clear face of the gauge, it's really hot. Is this normal? if not, what could it be?
EDIT: it's a mechanical gauge, if it matters.
This post has been edited by JoKeRkId613: Aug 12, 2007 - 12:42 PM
post Aug 12, 2007 - 2:58 PM
forkee
Joined Nov 13, '02
From So Cal
it shouldn't get hot. Is the lighting on it always on or something? since its mechanical the only thing attached to it that would make it hot are the wires for the lights.
post Aug 12, 2007 - 3:26 PM
JoKeRkId613
Joined Apr 25, '03
From Miami, FL
i drove the car last night with the gauge for the first time and the lights were on. i guess that could be what it was. i'll see if i get the same thing today in the day time. i'll look into swapping the bulbs out to LEDs - im assuming thatll help. thanks man.
post Aug 12, 2007 - 8:37 PM
6gsillyca
Joined Jan 13, '06
From UnderTheGround403
post a pic of your gauge.
post Aug 12, 2007 - 8:43 PM
Where did you wire the light power to?
post Aug 13, 2007 - 1:29 AM
vsideboy
Joined Mar 29, '06
From Hull, UK
if its mechanical then its got the vacuum pipe going to it as well. Not felt mine though but hot turbo air from the vac pipe would probably be heating the inside mechanism up too.
I would say its cos the lights on all the time though.
post Aug 13, 2007 - 9:24 AM
No turbo air gets to the gauge.
post Aug 13, 2007 - 10:03 AM
JoKeRkId613
Joined Apr 25, '03
From Miami, FL
i'll post pics when i get home tonight. yea, its the lights because it wasnt hot today in the morning. i wired them to the a/c control's pos/neg dimmer wires. it dims with the rest of the gauges. im supposed to be running 7psi but it only goes to 6psi. im 100% sure i hooked it up correctly. so i gotta see whats not letting me get the full 7.
Lo-Fi Version Time is now: November 24th, 2024 - 7:08 AM
