> Bigger Tires = Different Tire Pressure?
post Aug 14, 2007 - 12:25 AM
iparadox
Joined Jun 6, '07
From Vancouver, BC, Canada
If 29psi is the optimal tire pressure for the stock 185/70/14 tires, what should be the best tire pressure for 215/40/17's? The same or more?
post Aug 14, 2007 - 5:00 AM
tonytutino
Joined Jun 16, '06
From Bowling Green KY
i think alot of people with 17's run about 32psi
i do at least!
post Aug 14, 2007 - 11:06 AM
Gary
Joined Aug 28, '04
From FLA USA
Draw a line on tire tread using a chalk.
Drive in straight line for a distance and adjust the pressure accordingly.
_Gary
post Aug 14, 2007 - 9:10 PM
jdg371
Joined Jun 14, '05
33psi is what im running on 215/45/17, Tired of the tires folding when I take a "spirited" corner.. I bumped front to 35 and rear down to 33.
post Aug 15, 2007 - 9:23 AM
Redline08
Joined Feb 23, '07
From Albany, NY
man, i have a wicked long explanation as to how to get the best tire pressure but i really dont feel like explaining it lol.
Here:
http://www.team-integra.net/sections/artic...p?ArticleID=398
post Aug 15, 2007 - 1:03 PM
dustin15brown
Joined Aug 17, '03
From Bloomington, Indiana
It should say on the tire what the max pressure is... I leave my 215/35/18 @ about 40psi
post Aug 15, 2007 - 1:59 PM
Gary
Joined Aug 28, '04
From FLA USA
Something to keep in mind, too much tire pressure = less contact patch.
This post has been edited by Gary: Aug 15, 2007 - 1:59 PM
_Gary
post Aug 18, 2007 - 7:01 AM
jdg371
Joined Jun 14, '05
Overinflation = More wear in the center.
Underinflation = More wear in the outside.
post Aug 18, 2007 - 7:19 AM
BloodyStupidDave...
Joined Nov 14, '06
From Northampton, UK
QUOTE(iparadox @ Aug 14, 2007 - 6:25 AM) [snapback]587881[/snapback]
The stock 15" take 35. I put 35 or 36 in my 17".
post Aug 28, 2007 - 12:38 PM
Sinyk
Joined Oct 4, '06
From Kelowna, BC Canada
I thought my front tires (215/45/17) were looking a bit low and it turns out they were inflated to 29 psi when I had them installed. I recently bumped them up to 33, but is this ideal? Sounds like a lot of people vary their tire pressure. I want to make sure my pressure is good enough because I'm taking the Celi for a good 8 hour drive this weekend.
post Aug 28, 2007 - 1:40 PM
Rockford
Joined Dec 22, '06
From Caracas-Venezuela
i have 34 on my 215/45R17 goodyear F1
Celica ST202
Lo-Fi Version Time is now: November 25th, 2024 - 1:31 PM
