> Spark plugs covered in oil, rough idle on '97 7afe
post Aug 14, 2007 - 2:48 PM
kuarinyo
Joined Jul 26, '07
I have a rough idle problem and thought i'd change the spark plugs, i noticed the rightmost sparkplug's thread was covered in oil and the others werent. Only the thread had oil on it. Could this be a leak thats interrupting the spark to that last cylinder? Is there a seal or something I can replace? Any help appreciated, thanks.
post Aug 14, 2007 - 3:22 PM
95CelicaST
Joined Feb 5, '05
From pineapple under the sea
Sounds like you need a new valve cover gasket. The 7A-FE has four o-rings that go inside the valve cover and seal the spark plug area from oil. You'll need to take the screws off the top and pry up the little washers underneath of them and remove the plastic trim that runs over the top of the valve cover. Your valve cover should come off. You'll want to replace ALL of the gaskets in/on the valve cover.
This post has been edited by 95CelicaST: Aug 14, 2007 - 3:26 PM
**** Photobucket
post Aug 14, 2007 - 3:26 PM
Racer_J
Joined May 16, '07
From Newcastle UK
X2
Yep, my MR2 did the same thing. Didn't run rough though. Unless the electrode on the spark plug's covered in oil, that won't cause rough idling. Check your plugs/leads
post Aug 14, 2007 - 6:39 PM
cjh4l22
Joined Oct 18, '06
From cincinnati
i'm afraid i might be in a similar situation but i know my friend has that problem with his 5th gen.
post Aug 17, 2007 - 3:38 AM
creis
Joined Jan 10, '04
From Shoreline, WA
My impreza had this issue, easy fix, new O rings, valve cover gasket, easy on a inline 4 banger because there all up top, I had 2 on each side since its an flat 4 motor, very crampted space when taking the cover off frown.gif regardless, not a huge problem just general upkeep. should be less then an hours work, when I did mine it was 5 hours, but also did the timing belt at the same time.
the gasket kit for this job cost me $38 ish from B&B auto parts. (over 100 from the dealer and they sold me the wrong parts thus went to b&b.)
Lo-Fi Version Time is now: December 1st, 2024 - 2:37 AM
