> Bought my first Wideband.., now what??? ((pics)))
post Aug 15, 2007 - 11:50 PM
southwest2118
Joined Jan 13, '06
picked this up today.
I dont know where to put the sensor though. need help guys
reading a lil i found this .... whats right and whats wrong?
The sensor can often physically replace the
existing oxygen sensor, but for proper operation
of the ECU, it is often desirable to provide
another bung for the wideband sensor. We
recommend you place the NTK sensor a little
downstream of the existing sensor, and certainly before the catalytic converter.
"Always mount the sensor 15 degrees or more
to the horizontal (in the 10 to the 2 o’clock position with wires at the top)."
Some tuning shops use an adaptor that holds the oxygen sensor, and this adaptor is then
secured to the end of the vehicle’s tailpipe. This position is not recommended for vehicles with a
catalytic converter as the converter will change the readings you are measuring (that’s the cat’s
main function in life!). For carby vehicles (or non-operational cats on EFI vehicles) this position
may also be a problem as the exhaust gasses can be quite cool after travelling the length of the
car, and the sensors heater may have to work too hard to maintain an operational temperature.
Serious tuning will require a hotter position closer to the manifold.
Vehicles with a turbocharger should position the sensor after the turbo (and before the cat) as
a high exhaust back pressure (as will be found between the manifold and the turbo) has an effect
on the measured AFR and tends to read richer than is actually the case.
i'm running the 7afe on a t3 pushing 10psi with safc and 315cc injectors.....ummm the yellow top supra...
for the past year i've been wingin it......now i get to find out how rich i've been running....also the thing about this wideband is its not the 1-5volt kind most people use..its 1-3v kindasad.gif i guess its not too bad??
any advice other then get a new wideband will be appreciated ...
This post has been edited by southwest2118: Aug 16, 2007 - 12:01 AM
post Aug 16, 2007 - 12:27 AM
Harold_Fastwaker
Joined Aug 8, '07
From United States
I have always seen what the first quote suggests. Right around the area of the stock O2 bung but before the cat.
post Aug 16, 2007 - 9:01 AM
you should mount it right around your existing 1st o2 sensor bung.
just go down to your local exhaust shop and say o2 sensor bung please smile.gif
shouldn't cost more than $50 (if that) and then you can screw in the wideband and run the wires into the cabin smile.gif
and yes you want to run a lambda of 1.00 ideally
post Aug 16, 2007 - 10:39 AM
CaliJeff
Joined Apr 22, '07
From Bay Area, California
QUOTE(playr158 @ Aug 16, 2007 - 7:01 AM) [snapback]588397[/snapback]
yup yup, tell us how it goes !
You say you don't understand how we go dumb, but have you ever been where i'm from?
-=-] Livin it in tha bay's a lil different [-=-
Lo-Fi Version Time is now: December 1st, 2024 - 2:35 AM
