Enthusiast Joined Aug 21, '07 From bristol, UK Currently Offline Reputation: 0 (0%) ![]() |
i've been looking at new wheels for the celica and found these:
rimstock i preferred the team dynamics savage wheel, but in a charcoal colour. the problem is that the supplier said the required offset for the celica is 48mm on a 17x7 wheel. is this right? as i feel it would look too deep within the wheel arch. |
![]() Enthusiast ![]() ![]() ![]() Joined Oct 4, '06 From Kelowna, BC Canada Currently Offline Reputation: 3 (100%) ![]() |
QUOTE(phelon18 @ Aug 21, 2007 - 5:42 AM) [snapback]589629[/snapback] i've been looking at new wheels for the celica and found these: rimstock i preferred the team dynamics savage wheel, but in a charcoal colour. the problem is that the supplier said the required offset for the celica is 48mm on a 17x7 wheel. is this right? as i feel it would look too deep within the wheel arch. My 17x7's are a 40mm offset and they look fine. 48 is pretty much the biggest offset I think you would want to go, otherwise you could start to rub. -------------------- ![]() |
I had +42 and it looked fine in the front, but needed spacers for the back. 7th gen wheels are +39 and is the best offset, but those are 6.5". I say shoot for something between +35 and +42 and you'll be fine.
thanks guys.
i was a bit confused because i first read the sticky for wheel offset and it suggested a 36mm offset for a 7" wheel width and then the supplier gave a completely different offset. so if i go with the 38mm will i still need spacers for the rears? |
Nope, 38 should be just fine, especially if you lower it
![]() -------------------- 1991 MR2 - T-tops - Crimson Red - Gen3 3SGTE - Lots of money
Lo-Fi Version | Time is now: February 19th, 2025 - 9:54 PM |
