> subs not makin any sound, took them out of the car and now...
post Aug 21, 2007 - 3:59 PM
Redline08
Joined Feb 23, '07
From Albany, NY
I took my subs out of my car today to remove my bumper and i figured i play some music while i was at it. I played about half a song in my car when i realized that having my subs out of the car and playing was not a very good idea. I quickly put them back in and now they dont hit at allll, they hit slightly so they arent blown but you can barely feel them, i messed with my HU and amp for like an hour and they still do not hit like they used to!
Has anyone had this happen? and now im in the market for 2 new 12" subs if anyone wants to help that would be great lol
Thanks!
*edit*
they were working fine before i took them out of the car
This post has been edited by Redline08: Aug 21, 2007 - 4:00 PM
post Aug 21, 2007 - 4:06 PM
6th_celi_vert
Joined Jan 16, '06
From Kentucky
Is it a sealed, ported, or bandpass box?
post Aug 21, 2007 - 4:09 PM
Redline08
Joined Feb 23, '07
From Albany, NY
supposed to be sealed but there are 2 holes in the bottom so i can get to the subs
post Aug 21, 2007 - 4:14 PM
6th_celi_vert
Joined Jan 16, '06
From Kentucky
QUOTE(Redline08 @ Aug 21, 2007 - 4:09 PM) [snapback]589730[/snapback]
Then its ported. I was thinking that maybe if it was a bandpass then you had accidentally unhooked one of the subs inside the box and only one was hitted and making the other jump creating the illusion that both were working therefore also creating the illusion that both were working and you were only getting the sound of one.
...but nevermind, its a ported box so ill shut up now.
post Aug 23, 2007 - 11:38 AM
devilsden97
Joined Jun 13, '05
From Poughkeepsie, NY
swap the wires around.
alot of places/people hook them up backwards from where there suppose to be.
(easy to check, and an easier fix)
Kawi Love
post Aug 23, 2007 - 3:09 PM
MCelica
Joined Aug 13, '07
From Cyprus
This happen for three reason:
1) You disconnect coil wire. (your amplifier "see" more resistance)
2) Your enclosure is wrong builded (less damping out of car, destroy your subwoofer spider)
3) You play low notes out of car (destroy your subwoofer spider)
Check your amplifier "Gain" and your amplifier "crossover"
Measure with a multimeter your Subwoofer resistance and your amplifier AC Voltage
post Aug 24, 2007 - 11:42 PM
Redline08
Joined Feb 23, '07
From Albany, NY
so playing them out of the car probably destroyed the "spider"?
i actually did swith the wires around on one sub, but not both, i guess ill check tommarow...
Lo-Fi Version Time is now: November 25th, 2024 - 3:26 PM
