Redoing Brakes: NEED ADVICE... |
Aug 23, 2007 - 12:24 PM |
Enthusiast Joined Apr 18, '06 From Calgary, Canada Currently Offline Reputation: 37 (100%) |
So once the car gets back on the road; I'm going to start working on it from the ground up; starting with suspension/brakes.
I'd like to know; Brakes: (a) can ebay be trusted for crossdrilled rotors? What type of coating should I be looking for (anti-rust, etc.)?? Can I coat them myself and if so, what do I need? (b) What pad upgrade would be best with crossdrilled rotors? I'm looking for durability, quality, etc. © What is the best place to order from for rotors/pads combos? (d) Has anyone painted their calipers? If so, how hard was it to do? Did you take them off before painting, or just mask off the rotors, etc.?? Suspension: (a) I'd like to go with Tokico Blues and TRD springs; but what are some other suggestions for the best height : ride ratio? Any help is really appreciated. Thanks 6GC.net!! -------------------- |
Aug 23, 2007 - 1:34 PM |
a) buy brembo blanks...or slotted, cross drilled and slotted is not worth it.
b) hawks, akebonos c) if you do buy off ebay, contact the seller and see if they have a rotor/pad deal. d) when removing your rotors, and you hand your caliper on the side is the best time to paint...just wait til dry. a) depends what kind of drop u want. other good springs are teins, sprint, and tanabe -------------------- |
Aug 23, 2007 - 1:49 PM |
stay away from hawk HPS. while they stop well, the brake dust and noise is not worth it. i keep hearing good things about Greenstuff. might try those next.
Aug 28, 2007 - 12:07 PM |
Enthusiast Joined Aug 11, '07 From Corona, CA Currently Offline Reputation: 4 (100%) |
are there any other larger calipers from other cars that may fit on the celi? with little modification..
-------------------- Pandelica 2.0 in progress. |
Aug 29, 2007 - 8:35 AM |
check the stiky, i think there is one where the rears were changed from a st185 with no mod...
Aug 29, 2007 - 8:38 AM |
i get no noise or dust with my hawks in the fronts
Aug 29, 2007 - 8:43 AM |
a) don't buy brakes off ebay
b) EBC green stuff are awesome pads, i highly recommend them. Occasionally i would get a squeak from them when i first started driving but after a min of driving they quieted. Braking was definitely improved as well. c) TIRERACK.com has Brembo blanks for $35 a piece or ATE slotted rotors @ $30 as well...both are good choices. d) best time to paint...is when you are doing a brake job... Remove the caliper fully (disconnect them, don't worry this carries over to my next point) clean and paint them. e) You should CHANGE/FLUSH your brake fluid...This is a HUGE HUGE HUGE ignored/under estimated upgrade/maintenance. flush the entire system with Valvoline Syth. Dot4 or ATE SUPER BLUE. this will reduce the "squish" and give a better more firm peddle feel..as well as more consistent braking. f) another good investment would be SS braided brake lines. suspension wise, TEIN s-tech springs and bilstien shocks are a great combination. If you like coilovers Tein also has a great coilover setup for just around 1,000 USD. TRD springs are just "rebadged" more expensive Eibach Sportline (or Proline) springs (if i remember correctly) might as well get them straight from Eibach it would probably be cheaper. If you like coilovers, Ground control coilovers over a set of koni yellows would probably be the #1 best setup if you new correct spring rates and shock tuning. (more advanced setup obviously) This post has been edited by playr158: Aug 29, 2007 - 8:48 AM |
Lo-Fi Version | Time is now: December 1st, 2024 - 12:53 PM |
