Power Steering Fluid |
Aug 24, 2007 - 7:56 PM |
Enthusiast Joined Oct 19, '02 From Spring Valley, NY Currently Offline Reputation: 1 (100%) |
how do i flush my power steering fluid?? i have a 97 ST with 141,000 miles...it looks really dirty and gunky...
thanx for your help |
Aug 28, 2007 - 1:05 AM |
bump...i'm sure someone here knows how to do it...just give me some clue...
Aug 28, 2007 - 10:24 AM |
Enthusiast Joined Jul 29, '07 Currently Offline Reputation: 2 (100%) |
bump, i wanna know too...
Aug 28, 2007 - 12:06 PM |
You'll have to disconnect the line off the pump and drain everything.
Aug 29, 2007 - 11:21 AM |
Enthusiast Joined Aug 2, '06 From bay area Currently Offline Reputation: 21 (100%) |
look for an oil changers in ur area because they should offer that service.
Aug 29, 2007 - 4:48 PM |
Enthusiast Joined Jul 27, '07 From Québec, Canada Currently Offline Reputation: 0 (50%) |
Very easy Turn your whells to the very far right (or left), using a suction plew, remove the entire content of your power steering reservoir, refil with fresh atf derxon III fluid, and turn your wheels to the oposite direction, empty your reservoir, refil, and do it like this 2 - 3 times, adjust the fluid level as recommended and you're done It's the easiest and cleanest way to replace your power steering fluid, and your entire system is now filled with fresh fluid! Ho ho, you're welcome
Sep 2, 2007 - 9:40 AM |
thanx for the help guys...i knew someone here knows what their doing...
Lo-Fi Version | Time is now: November 23rd, 2024 - 4:18 AM |
