Driver Turn Signal, Doesn't turn on with the light switch |
Aug 26, 2007 - 9:33 PM |
Enthusiast Joined Jan 25, '06 From MN Currently Offline Reputation: 19 (100%) |
Hey all, just a couple of minutes ago I had to run to the store (its dark out) I turned on my lights and notice my drivers side turn signal didn't come on I though maybe the bulb went out but when I use the turn signal the lights blinks !? But it doesn't come on when I turn on my lights ?? Check all the fuses looks fine any ideas what it could be ??
-------------------- "To Protect And To Serve The Wealthy" -POLICE
Aug 26, 2007 - 9:52 PM |
Enthusiast Joined Nov 7, '06 From Lawrence IN, 46226 Currently Offline Reputation: 17 (100%) |
there are two filaments inside the bulb. mine did this. just replace the bulb and it iwll be fine. go ahead and replace both sides.
Aug 27, 2007 - 4:47 PM |
Enthusiast Joined Dec 26, '05 From So Cal Currently Offline Reputation: 1 (100%) |
QUOTE(mneal2_92788 @ Aug 26, 2007 - 9:52 PM) [snapback]591070[/snapback] there are two filaments inside the bulb. mine did this. just replace the bulb and it iwll be fine. go ahead and replace both sides. Exactly, it is a dual bulb. One filament is for your turn signal, the other for your running light. Just replace and you'll be fine, might as well do both sides while you're at it. |
Sep 2, 2007 - 11:06 PM |
I took the bulb out and it looked fine but when I replaced it with another it worked just fine. <--Rhymes Thanks for the help !!
Lo-Fi Version | Time is now: November 28th, 2024 - 3:37 AM |
