> Squeaking suspension
post Aug 27, 2007 - 5:20 AM
ss3beams
Joined Mar 6, '07
From Ireland
Hi I my suspension is squeaking something terrible at the moment replaced the stabilizer bushing but that wasn't it, it happens when going over bumps or any uneven surface really, it seems to be coming from all four corners - in wet conditions this is not a problem so it seems to be a lubrication problem anyone got any ideas?
post Aug 27, 2007 - 7:57 AM
azian_advanced
Joined Apr 18, '05
From Calgary
it's gotta be your shocks then...
if you stand on your door sills (for example) and start bouncing the car up and down, do you hear it squeaking?
post Aug 27, 2007 - 8:04 AM
ss3beams
Joined Mar 6, '07
From Ireland
QUOTE(azian_advanced @ Aug 27, 2007 - 1:57 PM) [snapback]591204[/snapback]
yes i do, but not half as much as when in motion - new shocks or just lube it up?
post Aug 27, 2007 - 3:37 PM
azian_advanced
Joined Apr 18, '05
From Calgary
you can't just lube it up, you'll need to replace them.
post Aug 27, 2007 - 7:14 PM
soven
Joined Mar 14, '05
From Auckland,New Zealand
just want to confirm that it is a squeak and not a knock?
post Aug 27, 2007 - 7:45 PM
post Aug 28, 2007 - 3:29 AM
ss3beams
Joined Mar 6, '07
From Ireland
QUOTE(soven @ Aug 28, 2007 - 1:14 AM) [snapback]591354[/snapback]
yeah definitely a squeak, goes away in wet conditions. slight knocking when coming off the accelerator
post Aug 28, 2007 - 5:58 AM
soven
Joined Mar 14, '05
It might be your Figure 8s of your superstrut that needs to be changed.
Have a look on www.gt4oc.net for diagnosing whether it is a superstrut problem , they know more about the suspension on your car.
example: http://www.gt4oc.net/viewtopic.php?t=67526...ighlight=squeak
post Aug 28, 2007 - 10:24 AM
ss3beams
Joined Mar 6, '07
From Ireland
QUOTE(soven @ Aug 28, 2007 - 11:58 AM) [snapback]591501[/snapback]
yeah i think that might be the knock when i come off the accelerator alright, the driver side shock is definitely gone anyway put it up on stands yesterday. have to get the shocks from japan €200 each (changing the front pair while i'm at it)
Lo-Fi Version Time is now: November 25th, 2024 - 9:23 AM
