my brake changing experience |
Aug 27, 2007 - 2:58 PM |
Enthusiast Joined Nov 7, '06 From Lawrence IN, 46226 Currently Offline Reputation: 17 (100%) |
so i needed new brake pads on the rear of my car. on one side the brakes taht i changed were still like new., but i went ahead and changed taht one no problem at all. but when i got to the side i knew needed the brakes, i went to get the bolt off to move the caliper, and the bolt snapped. so i went ahead and changed teh pads and they were down to the metal... this confused me b/c the other side were perfect, and these seemed like they were the originals. the pads were different in name and style. and they were diff colors. so now the bolt hole needs to be drilled and a new bolt put in. so i now have new pads, the roatrs are still good. and my caliper needs to be repaired, but it isnt moving so i know i can drive iwth it for a little while
Aug 27, 2007 - 7:49 PM |
something like this...
http://www.6gc.net/forums/index.php?showtopic=51194 Do you have any pics. I am preparing myself for this task. Have you found your part. I notices that my rear brakes only have one nut and the other is like a bolt. Did you removed both. Are they difficult to change. hope you fix your prob. do post pics... -------------------- Learned a lot in 10 years... I hardly log in anymore, last login Today Sept 6 2019, and I was forced just to clarify a post. LOL
Aug 27, 2007 - 11:30 PM |
QUOTE(njccmd2002 @ Aug 27, 2007 - 7:49 PM) [snapback]591376[/snapback] something like this... http://www.6gc.net/forums/index.php?showtopic=51194 Do you have any pics. I am preparing myself for this task. Have you found your part. I notices that my rear brakes only have one nut and the other is like a bolt. Did you removed both. Are they difficult to change. hope you fix your prob. do post pics... basically. i dont have anypics. i could take some tomorro and kinda do a re do. i didnt think there was a how-to on this. its not difficult at all. there is one bold, and the other is a plug like thing. when looking at the caliper, there will be a =one bolt on the backside that needs to be removed. once that is removed, just pull up on the caliper and the entire thing twist up. after that just pull off the brake pads and replace. if you would like i can do a detailed write-up with pics tomorro. or if you have any specific questions let me know and ill help my best |
Aug 28, 2007 - 6:55 AM |
no need for you to do a write up. So the bolt you can take out. The plug doesn. I thought maybe we were able to take the whole caliper out. So you twisted. That is self explan. No need to post pics. Ill go ahead and do it today see what happens....
Aug 28, 2007 - 9:32 AM |
alright, if you have any questions let me know.
Aug 28, 2007 - 6:06 PM |
Well, here it is. One wheel though, its too hot.....
took out the bolt... brake cleaner greased pads, and pushing the piston with the right tool... finished... -------------------- Learned a lot in 10 years... I hardly log in anymore, last login Today Sept 6 2019, and I was forced just to clarify a post. LOL
Aug 28, 2007 - 6:35 PM |
i think i have the brakes the other way around, the tabs on the tops
Aug 28, 2007 - 6:42 PM |
Does it matter? Thats how it was previously so i did it that way.
I guess it would do to the rotation of the disc. But it would matter when the brakes are worn. I dont know. On the other hand, because i was distracted i undid the middle bolt. and brake fluid came out. So i guess if i wanted to leak al break fluid to replace, has anybody done this. I cant find a sticky. thanks everybody for all your help... -------------------- Learned a lot in 10 years... I hardly log in anymore, last login Today Sept 6 2019, and I was forced just to clarify a post. LOL
Aug 28, 2007 - 6:53 PM |
you might need to rebleed your fluid, if air gets inside its not a nice braking feeling
Aug 28, 2007 - 6:59 PM |
i dont think air got inside, ill go try it aout around the block. i had the top off from the reservoir in the engine bay
Aug 28, 2007 - 7:26 PM |
well, test drove it, and i did not get killed. Ill do the fronts tomorrow.
Aug 28, 2007 - 8:14 PM |
i dont think it matters where the tab things are, i put mine on opposite what they were and they are perfect so oh well. at long as i can stop
Aug 28, 2007 - 9:52 PM |
Enthusiast Joined Oct 7, '06 From wyomissing pennsylvania Currently Offline Reputation: 2 (100%) |
i believe the tabs are just wear indicators, like when the pads wears to that point, the squeek against the rotor lettin ya know its time for new pads
-------------------- you know why they put sheep at the edge of a cliff.... that way they push back!
(2:27:32 AM) edit: please f*cking work, f*ck, sh*t, piss (2:28:08 AM) edit: that did the trick |
Sep 8, 2007 - 9:58 AM |
on another note, i was changing today my corolla brake pads. How do i make the rubber seal aroud the piston retract. I cnat make it go bak. any ideas...
Lo-Fi Version | Time is now: December 2nd, 2024 - 7:46 AM |
