> Part number request, Silvertop Valve Cover Gasket
post Aug 27, 2007 - 10:11 PM
95CelicaST
Joined Feb 5, '05
From pineapple under the sea
I pulled the plugs from the Yelli Celi (which were fowled) and went to get new ones. The ones I pulled were gapped at .50, but I'm not sure if thats the size it should be. Does anyone know what the proper gap should be on the silvertop?
EDIT: So last night when I was changing spark plugs I noticed little pools of oil in two of the three screw holes that hold the valve cover on. I cleaned up the oil and put everything back together. This afternoon after work I pulled the spark plug cover back off and found the pools of oil have returned. frown.gif
So I need to replace the valve cover gasket.. Anyone have the EPC and can look up that for me? Thanks!
This post has been edited by 95CelicaST: Aug 28, 2007 - 7:36 PM
**** Photobucket
post Aug 27, 2007 - 10:49 PM
hellsyphon
Joined Dec 3, '04
From torrance, ca
On a blacktop it's supposed to be at 0.043 so I'd assume that on a silvertop it should be similar if not the same.
post Aug 27, 2007 - 11:07 PM
95CelicaST
Joined Feb 5, '05
Well I read on club4AG that if I got the NGK's (which I did) that they should come pre-gapped, so I tossed them in with the gap provided (a bit over .30) and started it up and it ran fine, so I'll research a bit more tomorrow, but I think I did it properly.
until tomorrow....
off topic, but whilst I was under the hood today I wiped everything down and put a bit of wax around the engine bay. Now the inside and the outside shines! tongue.gif
**** Photobucket
post Aug 28, 2007 - 7:36 PM
95CelicaST
Joined Feb 5, '05
Edit in first post.
**** Photobucket
post Aug 28, 2007 - 10:02 PM
netrata
Joined Feb 16, '06
From Maui, Hawaii
Contact Herb at Cabe Toyota and ask him about the 20v valve cover gasket. He can also source a few maintenance 20v parts for you if you want. Here's his email address:
Herb@cabetoyota.com
post Aug 28, 2007 - 10:40 PM
soulshadow
Joined Apr 18, '05
From Lincoln, Ar
I copied and pasted this from somewhere. This is actually wat I have for myself. (The Spark Plug wires do not fit perfect but will work temp to get u home.)
SENSORS etc
16v coolant temperature sensor
16v air temp sensor
16v thermostat SILVERTOP ONLY
16v oil pressure sender unit
16v 4 wire heated O2 sensor (will need to be adapted to plug hole)
SEALS
16v distributor o-ring
Fuel Injector o-rings:
90301-14006 (the large o-ring towards the top of the injector)
90301-17007 (the smaller sized o-ring towards the bottom of the injector)
23291-75010 (another part number for the smaller sized o-ring)
16v oil filter sandwich seals
16v oil pump
16v oil pump seal
16v rear main seal
Overhaul Gasket Set P#: 04111-16330
Valve Stem Seals - $100
Exhaust P#: 90913-02092
Intake P#: 90913-02093
Waterpump o-ring: 96761-24035
Waterpump Bypass Hose: 16262-16030
Valve Cover Grommets (set of 3): 90210-09016
DRIVETRAIN
16v transmission - C50, C52 (obvious but might as well state it)
16v flywheels (212mm)
16v flywheel bolts
16v starter
16v clutches (212mm)
16v crank pulley
C52 Speedo sender shaft and gear: 33403-19285 ($26.50)
C52 Speedo sender housing: 33404-12030 ($18.03)
TIMING BELTS
16v timing belt tensioner
Silvertop Timing belt:
NAPA part #: 250081
Gates: T081
Bando: TB081
Dayco: 95081
Goodyear: 40081
Cadna: TB-081
TVI: TVI 081T
Blacktop Timing Belt:
JDM OEM Toyota Blacktop Timing Belt Part# 13568-16080
USDM OEM Toyota Blacktop Timing Belt U.S. Part# 13568-19185
MISC ENGINE
16v waterpump
16v alternator (if you use the 16v mounting bracket you can use the 16v belt)
16v air conditioner compressor
Oil Filler Cap: Stant oil filler cap #11121 (Advance Auto)
AFM & MAP
91 camry v6 AFM
93 MR2 Turbo AFM
late 90's Camry MAP
Igniter -- part no. 89621-12050, also found on:
MR2: 89/12-95/06 - (Mk2 Turbo)
Celica: 89/09-93/09 - (All-Trac)
Lexus SC300/400 91/04-A007?
Lexus LS400 89/05-94/10
Previa 90/01-97/007
4Runner, Truck 88/08-95/11 4x4 or 4x2
Truck (aka Hilux) 92/02-95/01 NAP 4x4
T100 92/08-98/07
Spark Plugs
91-93 MR2 Turbo spark plugs:
NGK BKR6E - V-power copper plug (what I use)
NGK BKR6EP - same as above but platinum.
NGK BKR6E-IX - same as above but Iridium
Denso K20R - standard copper Denso (AutoZone: K20R-U11)
Denso PK20R - same as above, but platinum.
Denso IK20R - same as above, but Iridium.
(0.044" stock gap is fine, you can go lower)
96 Camry wires (about 1.5" longer than stock, the stalks can be cut)
93-97 Corolla wires (only about 0.5" longer than stock)
3S-GTE distributor rotor
Lo-Fi Version Time is now: February 23rd, 2025 - 3:48 PM
