Manual KOYO into Auto Mod Done!!!!, MINI how-to now here. pics will be up soon |
Sep 9, 2007 - 11:21 PM |
Enthusiast Joined Mar 9, '05 From Oakland, Cali Currently Offline Reputation: 46 (100%) |
okay, after days of busy painting the c-one, working on weird shifts, i finally got time to do this MINI how-to.
NOTE: this how-to is just a reference for an AUTOMATIC 5SFE, i dont take account on yoru mistakes. that means, if you messed up im not the one responsible for anything. With that said, we can start. Pics are coming soon. ALSO, please read thru teh how-to BEFORE doing this mod. TIME doing this mod for me - 2.5 hours with breaks in between, MENTHOL cigarettes optional... TOOLS and PARTS needed: -obviously a KOYO radiator, from what the seller says - teh 2007 koyos comes with bigger cores -transmission cooler of your choice -new radiator cap, u can get either the KOYO radiator cap @ ebay OR get a STANT part # 11227. the stock cap doesnt fit. -new radiator hoses and worm clamps for radiator hoses and transmission hoses(mines looks ok, but it leaked after this mod. so gettin new hoses is a must!!!) -2 ft 3/8" transmission hoses -transmission cooler mounting kit (optional) -fittings (2) for your transmission cooler. my cooler has a 1/2" female npt, so ive used a 1/2' male npt to a 90 degrees 3/8" hose nipple -teflon tape -1 quart auto transmission fluid (more if u prefer to change your tranny fluid during this mod, auto 5sfe has a capacity of 3.5 quarts according to VALVOLINE) -2 gallons collant (i prefer PRESTONE 50/50) -new thermostat & water outlet gasket (recommended option, i didnt hcnaged mines even though i should) -12mm socket, 10mm socket, socket wrench, adjustable wrench, alligator pliers -jack and jack stands (2) -bucket to catch coolant & tranny fluid MAKE SURE the engine is cool and touchable to the hand before doing anything. Cars with cruise control might be a little different than what i did on this mod. 1. Jack up the car on jack stands 2. now take out undercar plastics, mines dont have any. most of the bolts are 10mm. 3. empty out old collant via a drain cock on lower right side of the radiator. 4. take out the lower radiator hose and unplug the coolant sensor from its harness and remove it with your adjustable wrench next to the drain cock (not sure if its a coolant sensor, some1 please confirm this), heres also yoru chance to change out the thermostat. take out yoru oil filter, and unscrew 2 of the bolts holding the water outlet. now jus pop the the thermostat out and change it out. re-install teh water outlet back in along with a water outlet gasket. 5. unplug 2 of the transmission hoses, those hoses are HARD to get off so i ended up cutting them. make sure u grab the bucket to catch some of the auto tranny fluid. 6. unplug 2 of teh fan motors harnesses, one is located next to the relay cover, one is located next to the far end of the radiator. 7. unplug the overflow tank hose, this is your optional chance to take the overflow tank off and empty teh old coolant. 8. take out the upper radiator hose and unbolt the radiator supprt bracket bolts (2 - 12mm bolts) 9. now PULL up on teh radiator making sure u dont pull anything off you're not suppose to. 10. take out the fans with 10mm bolts and transfer it to teh new and SEXY Koyo radiator. mount teh sensor back in the new radiator with teflon tape. screw the drain cock tight by hand, i forgot about this step and had some leak causing smoke. 11. nows your chance to mount the transmission cooler. before mounting teh cooler on your car, i recommend welding the cooler on your frame with enough space for the transmission hose to route thru teh undercarriage. i ended up using jus zipties but that'll change soon. of course, u can always use the cooler moutning kit they sell at your local auto parts store BUT teh way teh celica's condenser sits, it makes moutning the cooler very frustrating. Thats why i recommend welding it to the frame. You'll know what im talking about when you get to this step. I've mounted mines right on the middle of the condenser, i'll show u what i meant via pics coming soon. 12. install teh fittings with teflon tape, this step is very important~!!!!!!! Attach teh 3/8" hoses to teh cooler attaching teh clamps on. okay. heres teh hardest part of the mod. PULLING the hose off teh transmission. i found out a "ghetto" of taking those damn tight things off....i used a razor blade and cut the hose vertically in half while teh hose is on. now thats on, take a look on your hose routing. make sure that if u bottom out while driving, will it hit the hose. 13. ok, now you're ready to put the koyo in teh car. putting it back in requries some skill. some cars require u to install teh fans on teh radiator when your radiator is in the car due to space, mines was jus a drop in...while dropping in watch out for teh battery tray and teh left fan motor harness, they are a pain in the neck since you have a radiator in yoru hand. best to have a friend help u move the wires, harnesses out of the way. 14. install the coolant sensor harness. install teh lower radiator hose with worm clamps on both ends. (the oem clamps are a big nuisance to take off and on in place) plug the fan motors' harnesses, plug in the overflow tank (teh hose could be shorter on different cars, mines was just right) install the upper radiator hoses with worm clamps. 15. now that everything is on and tight. you're ready to pour on some coolant of yoru choice. ive put in some REDLINE water wetter along with 1.5 quarts of PRESTONE 50/50. its all on personal preference, u can jus put coolant on. okay, now put the radiator cap on. the OEM radiator cap is jus a tad smaller, so i got the STANT radiator cap and it fit snuggly on the koyo. also, make sure to fill yoru auto tranny fluid on the tranny dipstick. 1 quart should suffice. 16. Now you're done!!!!! turn on the car and let it idle for about 10 minutes with heater on HIGH, checking for leaks and runs on the engine bay AND undercarriage. Treat yourself to a menthol cigarettes for a job well-done. CHEERS!!!! If there's any other things i have missed please let me know. This post has been edited by DeW_H0e_GT: Sep 9, 2007 - 11:40 PM -------------------- |
Sep 9, 2007 - 11:36 PM |
Enthusiast Joined Apr 29, '03 From socal Currently Offline Reputation: 0 (0%) |
whats is that called? |
Sep 9, 2007 - 11:39 PM |
its called a radiator cooling plate aka air diversion plate....
Sep 10, 2007 - 1:10 AM |
Moderator Joined Apr 17, '03 From Rockland NY Currently Offline Reputation: 15 (100%) |
Nice job.
-------------------- I will return one day. |
Sep 10, 2007 - 3:48 PM |
who makes them for our car?
Sep 10, 2007 - 7:48 PM |
QUOTE(trdcelica94 @ Sep 10, 2007 - 3:48 PM) [snapback]594939[/snapback] who makes them for our car? OMG!!!....hey bro , use teh search button...its extra cool if u did.....i got mines from vincent_doggy but he dont sell them anymore....chances of gettin your hands on one right now is kinda low.....i think massbrandon has one for sale one time might wanna pm him about it...... OH WAIT!!!!....pm this guy..he's from italy...ask him about it - borghe or somthin liek that.....search for his username...... and again, plz use the search button next time.....i dont want my thread to be cluttered with useless and OFF-TOPIC coments...thanks in advance...GOOD LUCK finding one This post has been edited by DeW_H0e_GT: Sep 10, 2007 - 7:49 PM -------------------- |
Lo-Fi Version | Time is now: November 23rd, 2024 - 5:26 AM |
