> dead cylinder
post Aug 29, 2007 - 5:05 PM
rjbibeau
Joined Sep 6, '04
From oakdale Mn
so my car was strapped on the dyno and the tuner was adding fuel to my #2 cylinder and it wasn't responding. so as the car was runnign we took the spark plug wire off and noticed the engine idle didn't change...after pulling the plug out and seeing it was fine and was getting spark and was wet for the injector; we did a comression check on it and....yep nothing. did a leak down test at 100 psi and it was hissing throgh the oil cap. so i figure it as either bad rings, or a cracked ringland beacuase there is oil smoke when the engine is under load coming out of the breather tube on the valve cover. I was talking to some of my buddis and was told it could be a burnt valve, but i can't see that being the case becuase wouldn't the smoke exit out of the exhaust manifold? i'm gonna be pulling the head off prob sat or sun and i hope not to see any more damage than i am expecting.
post Aug 29, 2007 - 5:19 PM
toyotacrazy
Joined Mar 4, '06
From Ohio
QUOTE(rjbibeau @ Aug 29, 2007 - 5:05 PM) [snapback]591938[/snapback]
It sounds like you may have a blown head gasket. It may be blown between the oil return and the #2 cylinder.
This post has been edited by toyotacrazy: Aug 29, 2007 - 5:20 PM
post Aug 29, 2007 - 6:47 PM
this would probably be the reason for it.
post Aug 29, 2007 - 7:08 PM
QUOTE(lagos @ Aug 29, 2007 - 7:47 PM) [snapback]591967[/snapback]
seeing that pic, right above your sig, art, tells the whole story.
ringland or cracked piston would be my guess as well.
too much heat, my friend.
post Aug 29, 2007 - 7:30 PM
95celgt
Joined Oct 5, '03
From South TX.
OMG!!! NO INTERCOOLER!!!!!
Say bye-bye to the pison ringlands, it ran too hot and they broke!
post Aug 29, 2007 - 8:16 PM
eggman40
Joined Aug 17, '04
From California
QUOTE(lagos @ Aug 29, 2007 - 4:47 PM) [snapback]591967[/snapback]
laugh.gif man that was a solid explanation.
Find the problem, fix the leak, then get your self an intercooler and go easy on the boost and this shouldnt happen again.
post Aug 29, 2007 - 8:17 PM
Celiracer18
Joined Aug 23, '05
From Princeton, Minnesota
im pretty sure thats his old setup before the seals went out on his ct26. Im pretty sure he has an intercooler now.
-Brian
post Aug 29, 2007 - 8:28 PM
QUOTE(Celiracer18 @ Aug 29, 2007 - 9:17 PM) [snapback]591998[/snapback]
post Aug 29, 2007 - 8:30 PM
Celiracer18
Joined Aug 23, '05
yeah i suppose. BTW where you getting it tuned Rick?
-Brian
post Aug 31, 2007 - 12:22 PM
rjbibeau
Joined Sep 6, '04
From oakdale Mn
QUOTE(95celgt @ Aug 30, 2007 - 12:30 AM) [snapback]591982[/snapback]
those are old pics that was for the inital start up like last year. i custom did my own FMIC
QUOTE(Celiracer18 @ Aug 30, 2007 - 1:30 AM) [snapback]592001[/snapback]
it was at Modern automotive performance in plymoth....very knowledgeable group
i'll post up new pics of my new setup tonight probably and sunday i'll be tearing her down.
This post has been edited by rjbibeau: Aug 31, 2007 - 12:19 PM
post Aug 31, 2007 - 12:28 PM
rjbibeau
Joined Sep 6, '04
From oakdale Mn
how's your project going celiracer?
QUOTE(toyotacrazy @ Aug 29, 2007 - 10:19 PM) [snapback]591944[/snapback]
good thinking...never thought of that one
post Aug 31, 2007 - 8:51 PM
mr2nerkitty
Joined Aug 30, '07
From Belle Plaine
Try droppin a 3s....haha i have one! j/k
love you
post Aug 31, 2007 - 10:44 PM
rjbibeau
Joined Sep 6, '04
From oakdale Mn
i like my lil 5s thank you very much
post Aug 31, 2007 - 10:55 PM
Celiracer18
Joined Aug 23, '05
my project is pretty dead. im selling some of the stuf for other things and rebuilding a new motor (with some goodies) since mines questionable to say the least. i may even sell it all for a 3S ill have to see.
-Brian
post Aug 31, 2007 - 11:19 PM
mr2nerkitty
Joined Aug 30, '07
From Belle Plaine
QUOTE(rjbibeau @ Aug 31, 2007 - 10:44 PM) [snapback]592544[/snapback]
Haha ill agree with that your LIL 5s...it cant handle the rath of the turbo like the 3s can!
teehhheee
See even your friend here is getting a 3s
post Sep 1, 2007 - 7:19 AM
QUOTE(mr2nerkitty @ Sep 1, 2007 - 12:19 AM) [snapback]592551[/snapback]
teehhheee
i find this laughable.
ive seen more than a few 3s blown motors since ive had my 5sfte (2 yrs, over 30k )
post Sep 1, 2007 - 9:00 AM
Celiracer18
Joined Aug 23, '05
thats cause you're a pro Manny and you did it right and did your research ahead of time. thumbsup.gif Something i wish i spent more time doing rolleyes.gif
-Brian
post Sep 1, 2007 - 9:47 PM
toyotacrazy
Joined Mar 4, '06
From Ohio
QUOTE(rjbibeau @ Aug 31, 2007 - 12:28 PM) [snapback]592442[/snapback]
Yea but its just something to look for. You may as well put rings in it. If your going that far why not put better rods in it....and so on .....haha its so addicting biggrin.gif
Lo-Fi Version Time is now: November 30th, 2024 - 12:37 AM
