94-95 obd1 or obd2, for 5sfe and 3sgte |
Aug 30, 2007 - 10:20 PM |
Enthusiast Joined Nov 21, '05 From Quebec Currently Offline Reputation: 0 (0%) |
I have diagnostic connector with special plug under my hood
I have obd2 code reader with conventional 16 pin connectot Can I find adaptor....or maybe my 94 is not obd2 3sgte in japon is the same think I dont no difference from ecu number beetween 94 and 96 and for 5sfe In don't understand why injector 1-3 and 2-4 is wire together and coil inside distributor in my 94 and not for 96 -------------------- Celica GTS turbo 1994
3sgte genIII Ct20b |
Aug 30, 2007 - 11:25 PM |
Enthusiast Joined Jan 17, '04 From Boston, MA Currently Offline Reputation: 1 (100%) |
> 3rdgen3SGTE
> '94 GT-S Hatchback > From Quebec > I have diagnostic connector with special plug under my hood Plug under the hood is Just the engine diagnostic box. Pre OBD2. > I have obd2 code reader with conventional 16 pin connectot Good for you. It cannot read non-obd codes though. Just jump TE1 and E1, the engine check light will blink out codes. > Can I find adaptor....or maybe my 94 is not obd2 Some early '95's were OBD2 in the US. Not sure in Canada. '96 was the 1st offical year here. > In don't understand why injector 1-3 and 2-4 is wire together and coil inside > distributor in my 94 and not for 96 ? I dunno. Regards; -------------------------------------- |
Aug 31, 2007 - 10:47 AM |
tanks
So can I use my reader on connector near the steering... 94-95 are obd1.5 ???? I wait more info -------------------- Celica GTS turbo 1994
Aug 31, 2007 - 10:51 AM |
Enthusiast Joined Jun 13, '05 From Poughkeepsie, NY Currently Offline Reputation: 2 (100%) |
are we talking 3sgte or 5sfe? (u mentioned two engine codes, and im TOTALLY confused)
USDM 94 - 95 are OBD1 USDM 96-99 are OBD2 ^its fact Now if your talking CDM i would still say its the same. JDM...(3sgte) i have no clue. edit: for sucky grammar This post has been edited by devilsden97: Aug 31, 2007 - 10:53 AM -------------------- Kawi Love |
Aug 31, 2007 - 2:58 PM |
tanks it's so strange I don't know if I have obd1 or obd2 ecu for my 3sgte jdm....I have buy 2 ecu from ebay mr2 :89661-17460 and gt4 :89661-2b840....I don't see 96+ part #
Lo-Fi Version | Time is now: December 1st, 2024 - 1:54 PM |
