> 3sfe swapping
post Aug 31, 2007 - 6:01 AM
fran
Joined Apr 28, '07
From Venezuela
hi! guys!....i buy a 3sgte 2gen engine, then i wanth to do the swap into my St202(with a 3SFE) but i dont know how many more parts i must purchase before do the swap
the parts that i got its:
-complete engine
-AWD transmission
-intake & exhaust manifolds
-turbo
-intercooler
-alternator
-air conditioning compressor
-direction pump
-ECU
-All sensors
wath more parts i need to complete the swap???
THX
Fran!
post Aug 31, 2007 - 11:51 PM
3rdgen3SGTE
Joined Nov 21, '05
From Quebec
are you have cut harness
Celica GTS turbo 1994
3sgte genIII Ct20b
post Sep 2, 2007 - 12:44 PM
fran
Joined Apr 28, '07
From Venezuela
no, i have uncut harness
post Sep 3, 2007 - 2:57 AM
goferris
Joined Feb 14, '07
From Provo, UT USA
QUOTE(fran @ Aug 31, 2007 - 5:01 AM) [snapback]592359[/snapback]
-complete engine
-AWD transmission
-turbo
-intercooler
-alternator
-direction pump
-ECU
-All sensors
THX
Fran!
unless you plan on putting on a gt4 hood i think you are going to need to get a fmic. the tmic wont fit under the hood unless you do some custom hood work iirc. you will also need to purchase some gauges and a Lotek Gauge pod so you can monitor oil pressure and boost and such. you may also wish to invest in a turbo timer. GL on the swap
post Sep 9, 2007 - 6:34 PM
fran
Joined Apr 28, '07
From Venezuela
i will put an FMIC, yes i need to purchase the turbo timer and the gauges and a blowoff too.... i need some different motor mount? or the 3SGTE will fit without problems? my car its a GT. wath parts need to be replaced? rolleyes.gif
post Sep 9, 2007 - 6:41 PM
jcbass7
Joined Apr 20, '06
From Florida
TMIC fits under the hood. but i highly discourage it. i had the TMIC on there and was knocking when pulling hard because she heated up too much.
did you get the AFM?
GT should fit without needing different mounts
This post has been edited by jcbass7: Sep 9, 2007 - 6:41 PM
post Sep 12, 2007 - 8:04 PM
fran
Joined Apr 28, '07
From Venezuela
Then not need new motor mount, the engine fit perfectly into my ST202 without problems?
Wath more parts i need purchase? i must rebuilt my 3SGTE, need to buy new oil pump, wather pump, new gasket kit.
3SGTE SWAP HAVE TOO MUCH PROBLEMS???.... BECAUSE I CAN JUST POWER UP MY OLD 3SFE.
the main problem its the ECU istallation and the wiring? or its just easy to do all the swap?
Lo-Fi Version Time is now: December 2nd, 2024 - 10:13 AM
