> Shift Linkage
post Aug 31, 2007 - 8:23 PM
boosted185
Joined Aug 27, '07
From Summerville, SC
Alright, so i am doing a 3s swap and am running an MR2 tranny...whoever has this...what have you dont as far as shift linkage??????? Please help
www.tweakdperformance.com
contact@tweakdperformance.com
post Sep 1, 2007 - 9:57 PM
toyotacrazy
Joined Mar 4, '06
From Ohio
QUOTE(boosted185 @ Aug 31, 2007 - 8:23 PM) [snapback]592532[/snapback]
I used st205 shifter linkage. I got on ebay and found people in the UK parting/breaking st205 celicas. Then messaged them and they listed them on ebay. good luck
post Sep 2, 2007 - 4:54 PM
boosted185
Joined Aug 27, '07
The factory 205 linkage was long enough to reach all the way around to the front of the tranny to hit the levers???
post Sep 2, 2007 - 7:05 PM
toyotacrazy
Joined Mar 4, '06
From Ohio
QUOTE(boosted185 @ Sep 2, 2007 - 4:54 PM) [snapback]592844[/snapback]
it worked perfect for me
post Sep 4, 2007 - 3:17 PM
boosted185
Joined Aug 27, '07
anyone else using anything different?????
post Sep 4, 2007 - 3:34 PM
supershannon77
Joined Jan 18, '07
From Bergen county NJ
I highly recommend using the st205 cables anything else just doesnt work right. I had the stock st cables in and just switched to the st205 cables and it made a world of a differance!
facebook WRC st205
post Sep 4, 2007 - 4:00 PM
To do the conversion you can use ST185 tranny parts. The linkage bracket, as well as some other parts are bolt on. There is one place you will have to seal up a hole where you remove a piece, and also a place you will have to tap a hole.
As for shifter cables, use ST205.
Lo-Fi Version Time is now: February 22nd, 2025 - 8:46 PM
