> WTB- Window Regulator
post Sep 2, 2007 - 10:49 AM
toyotanut
Joined Aug 30, '04
From Westville, NS, Canada
The cable in my drivers side window regulator broke and i am looking for a new regulator. Do they come with the motor? Does anyone know where a good place to purchace one would be? the drum the cable wraps around is also messed up from the broken cable running on it. A new regulator would include this drum correct? If anyone has had a similar problem, and know how much the parts should cost and where to get them any information would be greatly appreciated, Thanks!
This post has been edited by toyotanut: Sep 2, 2007 - 12:14 PM
post Sep 2, 2007 - 11:32 AM
goferris
Joined Feb 14, '07
From Provo, UT USA
QUOTE(toyotanut @ Sep 2, 2007 - 9:49 AM) [snapback]592789[/snapback]
better add WTB to the topic name b4 it gets deleted..
sorry i don't know where you'd be able to find one. i am sure someone will be able to help you out though.
post Sep 2, 2007 - 11:38 AM
jason
Joined Oct 7, '06
From wyomissing pennsylvania
id have to get you the part number, but you can buy the regulator assembly seperate, it does not come with the motor, and comes with a new drum, i think i know what your talking about... it also comes with a lil plastic applicator type thing to hold it together while you snap it on, its a pain... but pretty straight forward, the dealer should have one for you, i think mine was like 80-82 n change for the assembly w/o motor, also while you have the door apart, make any window angle adjustments if any are needed, glass clunking over bad bumps, difficulty closing/sealing.
cant find the bag w/ sticker i got from the dealer to give you exacts, but i'll try n look it up on tuesday if you havent found an answer by then.
also if you want detailed instructions for the whole task of replacing this, i can try n scan in the info i have. pm me if i dont follow up on this and you need help =)
post Sep 2, 2007 - 11:47 AM
trdcelica94
Joined Apr 29, '03
From socal
you can purchase the regulator at the dealer. or the junk yard
post Sep 2, 2007 - 12:19 PM
toyotanut
Joined Aug 30, '04
Thanks everybody for quick responses!
Jason if you could scan any info you had on replacing the regulator that would be great
Lo-Fi Version Time is now: November 23rd, 2024 - 3:38 PM
