5SFTE Project Time, Updated with pictures. |
Sep 17, 2007 - 7:47 PM |
Enthusiast Joined Apr 22, '07 From Bay Area, California Currently Offline Reputation: 14 (100%) |
Parts left that i need...
28x7x3 intercooler & 2.25" Aluminum IC Piping 3an 18" steel braided feed line almost there guys !!! -------------------- You say you don't understand how we go dumb, but have you ever been where i'm from?
-=-] Livin it in tha bay's a lil different [-=- |
Sep 21, 2007 - 1:28 PM |
So i'm thinking of getting this one. I know this is a good brand, and it'll hold up to the psi and hp. Let me know.
Here -------------------- You say you don't understand how we go dumb, but have you ever been where i'm from?
Sep 21, 2007 - 1:57 PM |
Enthusiast Joined May 12, '06 From Wilmington, NC Currently Offline Reputation: 45 (100%) |
QUOTE(CaliJeff @ Sep 21, 2007 - 11:28 AM) [snapback]597911[/snapback] So i'm thinking of getting this one. I know this is a good brand, and it'll hold up to the psi and hp. Let me know. Here looks good. can't complain about the price either! -------------------- 94 GT - Sold -------- 69 Pontiac Lemans - Sold 88 Alltrac - Sold ---- 04 WRX - Sold 00 GT-S - Sold ------ 91 Miata - project/drift car 95 GT - Sold -------- 96 GT - New Daily Drive |
Sep 21, 2007 - 1:58 PM |
kk, it shall be mine then !! ordering it as we speak
Sep 22, 2007 - 10:51 PM |
this is how i would do right?
Oil restrictor - 3an Adaptor - Oil take off adaptor This post has been edited by CaliJeff: Sep 22, 2007 - 10:52 PM -------------------- You say you don't understand how we go dumb, but have you ever been where i'm from?
Sep 23, 2007 - 8:34 AM |
Enthusiast Joined Feb 26, '07 From Boston, MA Currently Offline Reputation: 1 (100%) |
QUOTE(CaliJeff @ Sep 22, 2007 - 11:51 PM) [snapback]598231[/snapback] this is how i would do right? Oil restrictor - 3an Adaptor - Oil take off adaptor doesnt your oil feed line have a male end on it?, i thought mine did, if so...you can get rid of the -3an adapter, and just spin the oil restrictor around and go right into the T. I dont know what your feed line looks like though. -------------------- |
Sep 23, 2007 - 11:39 AM |
neither do i lol. i get it tuesday i believe. i can't remember if it has a male end or female. Another question, i don't need any teflon tape here right? and what about the oil line, do i need teflon tape to connect it to the oil restrictor?
Sep 23, 2007 - 1:33 PM |
QUOTE(CaliJeff @ Sep 23, 2007 - 9:39 AM) [snapback]598315[/snapback] neither do i lol. i get it tuesday i believe. i can't remember if it has a male end or female. Another question, i don't need any teflon tape here right? and what about the oil line, do i need teflon tape to connect it to the oil restrictor? yeah, you'll want teflone tape on everything. except for on the block adaptor where it connects to the block. but everything else. -------------------- 94 GT - Sold -------- 69 Pontiac Lemans - Sold 88 Alltrac - Sold ---- 04 WRX - Sold 00 GT-S - Sold ------ 91 Miata - project/drift car 95 GT - Sold -------- 96 GT - New Daily Drive |
Sep 23, 2007 - 6:44 PM |
you should not be using teflon tape on any of the AN fittings.
only the NPT fittings should get it. AN fittings are flared to seal tight. -------------------- Former Team 5SFTE pro member ;)
13.6@108MPH, 5SFTE Powered |
Sep 23, 2007 - 7:08 PM |
kk.
Sep 25, 2007 - 9:29 PM |
So i got my gauges. Where do you put the wires thru the firewall?
Sep 26, 2007 - 1:27 AM |
pull off the drivers side wheel and fender plastic and you'll see some wires that run into the passenger compartment from the engine bay. that's the route I followed.
Sep 26, 2007 - 5:17 PM |
so one thing i have to figure out is, where to put my oil temp sensor. My oil pressure sensor is on the tunertoyz t. any ideas where to put the other? the only other way i can think of is to put on a sandwhich plate on the oil filter, so i can go in that way... tho i do not want to.
other question is relative to my water temp gauge. does anybody know the diamater for the INNER side of the radiator hose? thanks in advance! -------------------- You say you don't understand how we go dumb, but have you ever been where i'm from?
Sep 27, 2007 - 7:32 PM |
So FYI, i found out that for the inner side of the radiator hose is 32 mm. So now i'm gonna get a tap-in for that sensor.
Sep 27, 2007 - 10:08 PM |
Enthusiast Joined Aug 30, '02 From Maryland Currently Offline Reputation: 8 (100%) |
Couldnt you just pop the sender into where your T'ing the coolent into your turbo? Does the sender have the same pipe thread style sender as the oil one?
-------------------- Member of Team 5sfTe
Sep 27, 2007 - 11:19 PM |
i believe the sensor is 1/8 NPT. I looked at the oil temp sensor and the h20 sensor side by side as well. they appear to be the same thing. i used prosport premium gauges, and they sell adaptors with 1/8 NPT sensor threading as well to go along with the h20 sensor. it's $28 for the 32 mm adaptor. my oil pressure sensor is premium as well, it's a lot more sleak and james bondish to me lol. i'll put more pix up later of it. the sender is 1/8 NPT as well for that one too. it screws jsut fine into the Tuner Toyz fitting.
also, got my oil feed line (yay). both ends are female. 1 is 90 degree and 1 is straight. -------------------- You say you don't understand how we go dumb, but have you ever been where i'm from?
Sep 28, 2007 - 1:36 AM |
you could try to get another one of those brass Tees from monument like I gave you. they are like 3 or 4 dollars. then cut off the nipple that sticks out and get a 1/8" NPT tap and see if you can put threads in that and then just tee into one of the turbo coolant lines. and then you can just thread your fitting into that. cause I really don't understand how you are supposed to tap into the big radiator hose.
Sep 28, 2007 - 10:27 AM |
Like this. It's the 10th one down. Prosport Gauge Hardware.
Sep 28, 2007 - 11:37 AM |
so here is my feed line i got along with the oil pressure sensor.
Here's the whole line THe MBC Spark plugs Parts needed down to nuts and bolts. bolt for Wastegate actuator bracket -? oil pan gasket - ? Oil line gasket - $8 oil return line - $30 - Pending w/ someone IC piping - $120 w/ shipping - already know where to get it Exhuast piping from cat to DP - $100_200 ? -------------------- You say you don't understand how we go dumb, but have you ever been where i'm from?
Sep 28, 2007 - 2:50 PM |
That coolent settup is nice and all but you could get the same settup with a T fitting (All 3 sides female npt) 2 3/8's barb hose fittings with male ends. Shouldnt cost more then $5 in parts from a plumbing store
Lo-Fi Version | Time is now: December 3rd, 2024 - 2:58 PM |
