5SFTE Project Time, Updated with pictures. |
Sep 28, 2007 - 8:20 PM |
Enthusiast Joined Apr 22, '07 From Bay Area, California Currently Offline Reputation: 14 (100%) |
where would i "T" in to then? Cuz i have to take the turbo off techincally when i go into smog. if i tap-in to the radiator hose, i can keep everything legit.
-------------------- You say you don't understand how we go dumb, but have you ever been where i'm from?
-=-] Livin it in tha bay's a lil different [-=- |
Sep 28, 2007 - 8:53 PM |
Enthusiast Joined Aug 30, '02 From Maryland Currently Offline Reputation: 8 (100%) |
If your running the coolent plumbing from under the TB you could just pop a T fitting into the prong fitting or whatever your using to extend the coolent lines. I added an extra 14 inches or so onto each coolent line with the barb fitting, plenty of room for a sender in there.
-------------------- Member of Team 5sfTe
Oct 1, 2007 - 9:50 PM |
small update. i got in a bike accident yesterday. i won't be able to work on the car for maybe a week or 2. hopefully sooner. i had an IV in each arm, and several cat scans. i got road rash all up my right side of my face and my hands/arms, which went along with a concussion following a blackout. it's alright tho, got myself a bunch of Norco, should help a lil.
i'll keep u guys posted. Love your fellow 6GC member, Jeff PS I'll get better fast, swear ! -------------------- You say you don't understand how we go dumb, but have you ever been where i'm from?
Oct 1, 2007 - 9:54 PM |
Get well and feel better soon dude!
Oct 1, 2007 - 11:44 PM |
Enthusiast Joined May 12, '06 From Wilmington, NC Currently Offline Reputation: 45 (100%) |
hope you feel better soon! livermore needs another turbo 6gc!
-------------------- 94 GT - Sold -------- 69 Pontiac Lemans - Sold 88 Alltrac - Sold ---- 04 WRX - Sold 00 GT-S - Sold ------ 91 Miata - project/drift car 95 GT - Sold -------- 96 GT - New Daily Drive |
Oct 4, 2007 - 12:33 PM |
Enthusiast Joined Apr 16, '04 From Raleigh, NC Currently Offline Reputation: 1 (100%) |
how could you go and do a thing like that???
hope you get to feeling better...can't wait to see how the project turns out! |
Oct 22, 2007 - 9:02 PM |
So after 3 weeks of finally getting well or at least better as to what i was before, i'm going to resume my project. i ordered a KO DP instead of the one i received from 6strings (sold it back to him), and i need to now just save up a lil bit of money again in order to need the following items:
3s oil drain line intercooler piping magnaflow highflow cat custom piping from dp to cat PS: For those who have an aftermarket oil temp. sensor, where did u make an adaptor or where did u place the sensor? The only way i have been able to think of is the sandwhich plate adaptor - which i do not want to buy. Please state ur input, thanks guys ! -------------------- You say you don't understand how we go dumb, but have you ever been where i'm from?
Oct 22, 2007 - 9:05 PM |
do you wanna buy my 3" magnaflow cat convertor?
Oct 22, 2007 - 9:06 PM |
neg, i'm doing 2.5" all the way.
Oct 27, 2007 - 8:37 PM |
another question. for the coolant lines, underneath the throttle body, does it matter which lines from the turbo go to? or just hook up to what i can. i know there is 3 of em, and i need to use the one to the left, and the one to the right.
Next question, when i tee into the line for the preturbo, do i need to hook up the line before the catch can, or can someone else further explain this please -------------------- You say you don't understand how we go dumb, but have you ever been where i'm from?
Oct 27, 2007 - 10:03 PM |
QUOTE(CaliJeff @ Oct 27, 2007 - 6:37 PM) [snapback]608914[/snapback] another question. for the coolant lines, underneath the throttle body, does it matter which lines from the turbo go to? or just hook up to what i can. i know there is 3 of em, and i need to use the one to the left, and the one to the right. Next question, when i tee into the line for the preturbo, do i need to hook up the line before the catch can, or can someone else further explain this please You can use any of the 2 coolent lines, doesnt matter which coolent hose you hook into on the turbo side because its a shared line, just flows arounf and then back out. Im assuming your talking about the hose from the valve cover being T'd off.... Routing it to a catch can and then to the intake is a good idea, valve cover to the turbo is also fine. -------------------- Member of Team 5sfTe
Oct 27, 2007 - 10:08 PM |
so, from the valve cover to the t, 1 end goes to the turbo, 1 end goes to the catch can, then from the catch can to the intake ?
Oct 27, 2007 - 10:12 PM |
No no, valve cover to catch can to the intake. Your not thinking coolent still are you?
Your using the catch can like a filter, the bad air/fumes go in and anything that can settle in there will and less will be re-breathed back into the intake. This post has been edited by 1bwilson: Oct 27, 2007 - 10:13 PM -------------------- Member of Team 5sfTe
Oct 27, 2007 - 10:18 PM |
lol, no no, not thinking coolant. i know how a catch can works. so u are saying only do one method for the intake, don't combine both?
Oct 27, 2007 - 10:22 PM |
Yes, you want it to flow threw the catch can and into the intake.
Oct 27, 2007 - 10:23 PM |
thanks, that clears up a couple questions !
Oct 28, 2007 - 8:18 AM |
QUOTE(CaliJeff @ Oct 27, 2007 - 11:23 PM) [snapback]608936[/snapback] thanks, that clears up a couple questions ! jeff, this pic shows exactly how it should be routed. if your using a catch can, the line would go from the valve cover, to the CC, and from the catch can, to the intake. -------------------- Former Team 5SFTE pro member ;)
13.6@108MPH, 5SFTE Powered |
Oct 31, 2007 - 1:24 PM |
small update, relocated my battery to the trunk.
Nov 1, 2007 - 12:17 AM |
you should bring your car over friday evening if you have time. I still want to see how you relocated the battery cause I'm pretty sure I'm going to relocate mine this time around.
Nov 12, 2007 - 4:28 PM |
another small update, hooked up my gauges, small question tho. with my oil pressure gauge, it reads 60 psi right when i start it, then after 2mins of driving it around, and placing it back in idle, it stays at around 25 psi, then when i rev, it will go up to around 40 psi or so, or if i rev higher, it will go to around 65 psi. any comments?
Lo-Fi Version | Time is now: December 3rd, 2024 - 2:49 PM |
