RPM dips then car shakes at idle |
Sep 3, 2007 - 8:49 AM |
Enthusiast Joined May 24, '06 From sydney Currently Offline Reputation: 0 (0%) |
Hi, just recently my 5sfe has started to idle weird. Sometimes it idles at 600-700rpms, then suddenly dips to below 500 rpms and then my car shakes as though im about to stall.
i changed spark plugs not long ago. Does anybody know what else i should check for? |
Sep 3, 2007 - 10:04 AM |
aic and o2 sensor could be bad or aic needs cleaning
Sep 3, 2007 - 10:33 AM |
Enthusiast Joined Jun 8, '07 From Houston, Texas Currently Offline Reputation: 1 (100%) |
QUOTE(LewFX @ Sep 3, 2007 - 3:04 PM) [snapback]592961[/snapback] aic and o2 sensor could be bad or aic needs cleaning where are these located? I feel like mine wants to do that sometimes where is everyone idling at anyways? I go to 800-900 but sometimes w/ AC on it varies lower -------------------- |
Sep 3, 2007 - 10:39 AM |
o2 is on exhaust manifold, aic is on intake manifold
Sep 3, 2007 - 11:43 AM |
Enthusiast Joined Nov 7, '06 From Lawrence IN, 46226 Currently Offline Reputation: 17 (100%) |
im at 500-600 at idle
Sep 3, 2007 - 2:18 PM |
Enthusiast Joined Jul 5, '07 From 626 Currently Offline Reputation: 0 (0%) |
i have the same exact problem wit my car right now after i cleaned my engine bay.. duno wat to do
Sep 3, 2007 - 2:56 PM |
check distributor, plugs, wires, and air filter. i needed a complete tune-up when my car did something exactly like this.
Sep 3, 2007 - 3:00 PM |
Enthusiast Joined May 13, '07 From riverside, ca Currently Offline Reputation: 0 (0%) |
i had the same idle problem and after i cleaned my IAC or idle air control valve the problem went away. beside it could be just the hot weather , i heard that older engine start to idle weirdly in hotter weather. but clean your IAC anyways , its easy and its only going to cost you a can of Carb cleaner
Sep 5, 2007 - 4:38 PM |
idles weird w/ a/c on? hows it idle without the a/c?
Lo-Fi Version | Time is now: December 3rd, 2024 - 11:17 PM |
