> vavle seal ?
post Sep 3, 2007 - 8:54 PM
blckcelica95
Joined Nov 20, '03
From Derry, NH
ok so my car has recently started eating oil . and today the car started smoking only at idle with a very burnt oil smelll. then during driving there is no smoke .i popped out the spark plugs and there dosent appear to be any residue on the plugs. it also idle almost perfectly when it smokes .so im going to rule out the head gasket but could it be vavle seals?
Driving a 5SFTE and LOVIN IT!!!!!!
http://www.myspace.com/17psicelica <-- celica engine build pics
post Sep 5, 2007 - 3:14 AM
mikeismad0408
Joined Mar 22, '07
From Greenville NC
sounds like my car. i was told it was the valve seals.
post Sep 13, 2007 - 10:11 AM
97Celica
Joined Nov 27, '02
From Derry,NH USA
Same with mine but I puffed smoke in between gears...my car is gone til saturday but I am replacing my timing belt,accessory belts,head gasket,valve seals and my water pump...I figure I am at 172,000 and just replaced my transmission at 150,000 that I should be able now to hit that 300,000 run that a toyota can go tongue.gif
My uncle who is my mechanic said that Toyotas are FAMOUS for their valve seals going...but,that's really the only "problem" with them.
post Sep 14, 2007 - 10:13 AM
hurley97
Joined Mar 3, '04
From Portsmouth, RI
yes. smoke at idle is bad valve seals
smoke while driving is bad piston rings
I <3 Dustin---07/16/06
post Sep 15, 2007 - 4:57 PM
bindertch
Joined Aug 18, '04
From Silverdale, WA
Blue or black smoke at any time is oil burning, white smoke at any time is coolant burning. Blue smoke only at startup is valve seals and during running or acceleration is usually rings.
post Sep 15, 2007 - 7:48 PM
elvasoshexai
Joined May 16, '05
From Toronto, Ontario
i just replaced my valve seals last week... expensive as hell... i had the problem of some smoke @ startup even tho car still ran beautifully...
06 Civic EX
My For Sale Thread
post Sep 16, 2007 - 11:08 PM
95CelicaST
Joined Feb 5, '05
From pineapple under the sea
Yeah, the Yelli Celi is having this issue. Its running rich and burning oil through the valve seals. If I'm sitting at a stop and I take off I leave a nice ploom of smoke... frown.gif
AE111 coming soon...
**** Photobucket
post Sep 17, 2007 - 9:32 AM
56willysnut
Joined Nov 29, '06
From Newnan, Ga.
I replaced the valve stem seals on our 7AFE, requires several specialized tools to do the job and took about 4hrs. Here's one tool;
[url= http://cgi.ebay.com/ebaymotors/Valve-Stem-...sspagenameZWDVW] [/url]
And another;
[url= http://cgi.ebay.com/ebaymotors/Valve-Sprin...1QQcmdZViewItem] [/url]
This tooling allows seal replacement with out removing the head. The PITA is the stem keepers. If you drop one down into the crankcase!!!!
Seals are about $40.
post Sep 19, 2007 - 8:50 PM
tonytutino
Joined Jun 16, '06
From Bowling Green KY
i think i've got the same problem, except there is oil on my spark plugs...
post Sep 19, 2007 - 9:09 PM
95CelicaST
Joined Feb 5, '05
That could just be your valve cover gasket. Change that.
**** Photobucket
post Sep 20, 2007 - 9:27 PM
1995ST
Joined Aug 26, '07
From Norfolk, VA
Dan
AIM: Oldsyota
My Cardomain
post Sep 22, 2007 - 3:58 PM
twitchh17
Joined May 19, '06
From North NJ
my car has blue smoke come out of the muffler whenever i start my car in the morning or if it sits for long periods of time. my cars at 182,xxx miles right now. what will happen if i dont do any of the fixing how long will it last? how much does it cost to get valve seals done and all that stuff? i just changed my spark plugs and got a oil change. my uncle told me to get spark plug seals and change the valve cover and get a new valve gasket. any other things i can do to maintain it well?
Lo-Fi Version Time is now: November 28th, 2024 - 2:58 AM
