7afte aka "smokey" |
Sep 6, 2007 - 10:42 AM |
Enthusiast Joined Feb 27, '07 From cape coral/ft myers florida Currently Offline Reputation: 7 (100%) |
so lets get down to stopping the 7afte smoking problem
ok so i have absolutely NO leaks in my system anywhere my return line has no bends in it so oil cant puddle in it i have an oil reducer in the feed line now what happens is under 3lbs or more of boost it will blow smoke out of the exhaust but when i stop or come out of boost it doesnt if i just drive normally (only going to 1 or barely 2lbs) there is no smoke at all so does anyone have any ideas of how to stop this and ive heard of using 2 reducers in the feed line does that sound like a good idea This post has been edited by jesterwr217: Sep 6, 2007 - 10:43 AM -------------------- BOOST GETS YOU LAID!!!! |
Sep 6, 2007 - 11:07 AM |
do you have an oil pressure gauge?
if not you should get one and find out what you are getting second answer = blow by |
Sep 6, 2007 - 11:13 AM |
its a brand new turbo so the seals are good but if i were to put a gauge in where in which line would i put it
Sep 6, 2007 - 11:20 AM |
Enthusiast Joined Aug 30, '02 From Maryland Currently Offline Reputation: 8 (100%) |
Oil feed line, not sure if your feeding from the head like the 5sfTe'rs but thats a decent spot to hook up.
-------------------- Member of Team 5sfTe
Sep 6, 2007 - 11:24 AM |
QUOTE(1bwilson @ Sep 6, 2007 - 12:20 PM) [snapback]593911[/snapback] Oil feed line, not sure if your feeding from the head like the 5sfTe'rs but thats a decent spot to hook up. yea straight from the head where the stock oil temp hooks up -------------------- BOOST GETS YOU LAID!!!! |
Sep 6, 2007 - 6:32 PM |
Enthusiast Joined Feb 26, '07 From Boston, MA Currently Offline Reputation: 1 (100%) |
do you have an oil restrictor on there?
Sep 6, 2007 - 6:56 PM |
QUOTE(jesterwr217 @ Sep 6, 2007 - 8:42 AM) [snapback]593903[/snapback] have an oil reducer in the feed line I think so -------------------- Member of Team 5sfTe
Sep 7, 2007 - 9:19 AM |
ahhh come on noone has fixed this prob yet??
Sep 7, 2007 - 9:41 AM |
ok, well first thing you NEED to do, is go down to advanced auto or something or order one from here
http://www.42draftdesigns.com/vdo.htm so that you have an oil pressure gauge. get a T-fitting for your oil pressure sender output on your block, run the aftermarket one, OEM one and your oil feed line to the T. you need to find out what the oil pressure is, so that further diagnosis of your problem can occur. without knowing the pressure its needle in a hay stack / flying blind looks like so you would actually have to T into it again in order to hook up the gauge, i would T it @ the restrictor on the turbo for the aftermarket gauge. This post has been edited by playr158: Sep 7, 2007 - 9:44 AM |
Sep 7, 2007 - 9:55 AM |
doesnt sound hard should i tee it before or after the reducer
Sep 7, 2007 - 10:11 AM |
thats a good question haha,
maybe Jgreen/p2 can answer that. i would assume after the reducer would be more accurate about what the turbo is getting? |
Sep 7, 2007 - 10:24 AM |
QUOTE(playr158 @ Sep 7, 2007 - 11:11 AM) [snapback]594191[/snapback] thats a good question haha, maybe Jgreen/p2 can answer that. i would assume after the reducer would be more accurate about what the turbo is getting? yea i just realized that rereading that wow that was a dumb question lol id have to put it after lmao -------------------- BOOST GETS YOU LAID!!!! |
Sep 8, 2007 - 6:32 PM |
Enthusiast Joined Jan 9, '05 From green springs ohio Currently Offline Reputation: 1 (100%) |
i had the same problem with my setup , i even put in two reducers ,still smoked in boost . i know i was only running around 20psi of oil pressure to the turbo, to fix my problem i used 1/2 in return line with no sharp bends i do not blow smoke any more , my old return line was the 3/8in size i think everyone uses, or gets with there oil return kit , but it did not work for me. 1/2in works great and i have no troubles for over a year.
Sep 8, 2007 - 11:17 PM |
Enthusiast Joined Jul 10, '05 From Monroe, WA Currently Offline Reputation: 6 (100%) |
trd said it.. im pretty sure the return line is the 2nd overlooked piece to the puzzle 2nd to the feedline reducer. give it a try.
-------------------- 94' ST Coupe - 5sfe Motor swap and brake swap.
Sep 20, 2007 - 7:04 AM |
Enthusiast Joined May 14, '06 From Miami FL Currently Offline Reputation: 0 (0%) |
check your valve seals under boost load you may be getting some oil in the exhaust ports . 2 car our a compression test and see what your numbers are, you may have lifted your head gasket
Lo-Fi Version | Time is now: November 25th, 2024 - 1:04 PM |
