![]() Enthusiast ![]() ![]() ![]() Joined Jun 8, '07 From Houston, Texas Currently Offline Reputation: 1 (100%) ![]() |
First off, I just got wires to hook up my old CD Deck, should it be simple as crimping the wires together and putting the deck in or do I need a special adapter to hold the body of the deck. (does the OEM work fine?)
Secondly, the interior cloth on my passenger door panel is starting to come off. I pulled a corner out a while ago on accident and now its getting worse. How would I go about fixing that. I am talking about the part that is above the armrests on the doors. Thanks guys. Edit: For te deck, Ive narrowed it down to a couple wires, crimped the rest so im almost done. There are a few that are stumping me. These are the wires that I can't connect to anything: orange w/ black stripe, orange w/ white stripe, and blue. I think the blue one is power antenna but on my cd deck, the blue wire is just crimped off by istelf. What are these wires for? Also, the old wiring harness for my honda had one yellow wire coming out, the red one was crimped off, and the yellow wire from the harness attached to a red and a yellow wire from the cd deck. The NEW harness I have has a red and yellow wire but I don't know if I need to do the same thing, crimp off the red one and use the yellow to connect to red/yellow or connect the wires to their respective others. L This post has been edited by cHinaman727: Sep 7, 2007 - 9:34 PM -------------------- |
![]() Enthusiast ![]() Joined Feb 27, '07 From Jacksonville Currently Offline Reputation: 0 (0%) ![]() |
I can't answer your question about the cd deck, but as for the door cloth, mine did that too. I used spray adhesive, and so far they've held up alright.
-------------------- 1997 Limited Edition Vert (((SOLD))) |
QUOTE(ecaddiction @ Sep 8, 2007 - 12:05 AM) [snapback]594314[/snapback] I can't answer your question about the cd deck, but as for the door cloth, mine did that too. I used spray adhesive, and so far they've held up alright. what did you use to get the edges back into the crevice? i figure a credit card or something like that would work -------------------- |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jun 29, '03 From 캘리포니아 Currently Offline Reputation: 23 (100%) ![]() |
That is happening to my doors too so sad
![]() But I can answer your audio question. You are installing a new aftermarket CD player right? Well the factory brackets should work just fine if it's a double din. If you have a single din, then it will still bolt up, but you'll have an empty space underneath. Unless you are already single din and have a storage space or w.e there already. Secondly, it should plug right in after you have spliced up all your connections to a wiring harness, but you need to plug it into the 2 plugs that are attached to under the factory amplifier. Just pull them off. The plug that is plugged into the factory radio will not plug into anything, so you can remove the factory amp and wiring as it will do nothing from now on. -------------------- |
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Jul 26, '07 From riverside,CA Currently Offline Reputation: 0 (0%) ![]() |
u need to buy the harness for the cd deck
-------------------- QUOTE(thespacepanda @ Feb 21, 2008 - 4:37 PM) [snapback]644164[/snapback] When I worked for Pizza Hut our store won a health code violation. |
Is the blue and orange wires coming from your car?
Here is all the help you need right here. www.installdr.com This post has been edited by MaskedMan: Sep 7, 2007 - 9:49 PM -------------------- |
QUOTE(MaskedMan @ Sep 8, 2007 - 2:32 AM) [snapback]594338[/snapback] That is happening to my doors too so sad ![]() But I can answer your audio question. You are installing a new aftermarket CD player right? Well the factory brackets should work just fine if it's a double din. If you have a single din, then it will still bolt up, but you'll have an empty space underneath. Unless you are already single din and have a storage space or w.e there already. Secondly, it should plug right in after you have spliced up all your connections to a wiring harness, but you need to plug it into the 2 plugs that are attached to under the factory amplifier. Just pull them off. The plug that is plugged into the factory radio will not plug into anything, so you can remove the factory amp and wiring as it will do nothing from now on. what about those wires i talked about ^^ i edited my post -------------------- |
I edited my post too
oh the oj/white one is the "dimmer?" what is the oj black?
and which one is the ground? im dumb lol This post has been edited by cHinaman727: Sep 7, 2007 - 10:08 PM -------------------- |
QUOTE(cHinaman727 @ Sep 7, 2007 - 8:03 PM) [snapback]594346[/snapback] oh the oj/white one is the "dimmer?" what is the oj black? and which one is the ground? im dumb lol Ground from the radio or from the car? They should both be the same color anyways and just connect to each other. -------------------- |
QUOTE(MaskedMan @ Sep 8, 2007 - 3:27 AM) [snapback]594349[/snapback] QUOTE(cHinaman727 @ Sep 7, 2007 - 8:03 PM) [snapback]594346[/snapback] oh the oj/white one is the "dimmer?" what is the oj black? and which one is the ground? im dumb lol Ground from the radio or from the car? They should both be the same color anyways and just connect to each other. when the radio was in my honda, there was no ground Oh but I found the ground from the deck and the harness... Can I just conect the two or do I have to use a ring terminal to ground it inside the dashboard? i think the old one just had it connected hmmm This post has been edited by cHinaman727: Sep 7, 2007 - 11:02 PM -------------------- |
Grounding it to the harness would be the usual choice.
got it in! sounds great and i dont even use the old amp
btw im sellin the amp and the stock cd deck/tape. its the double one so lemme know guys! ill post in fs later -------------------- |
Lo-Fi Version | Time is now: February 23rd, 2025 - 12:56 PM |
