Sep 10, 2007 - 6:49 AM
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Feb 18, '06 From NB, Canada Currently Offline Reputation: 12 (100%) |
Ok guys, if any of you are inteterested in getting a HID bi-xenon retrofit into their cars, same as I did on mine, I'm able to finally offer my services.
A full retrofit will include 2 oem ballasts, 2x 4300k bulbs, infiniti FX35 bi-xenon projectors (low-beam and high beam function) and 4 clear lens and proper wiring instructions. Please note I use USED OEM components, which has proven to way wayy wayy better than all the HID kits from china you can find on ebay and everywhere else. The headlight are returned with the custom lens, sealed, approximately aimed, and your stock lens along with it, though YOU CANNOT RETURN TO STOCK AFTER. You are responsible to wire them to your car,aim these lights after and check for local law for legality of this. Price is 675$, you ship your 4 headlights, I do the retrofit the day I receive them and ship them the day after. The return shipping price is included in the 675$. I can only do this on a first come first serve basis and I don't know how much I can do due to supplies. NEW NEW NEW NEW If you guys want ONLY the retrofit (4 lens + bi-xenon projectors) and use your own HID hardware, I can do the retrofit for 300$ + shipping. You can mod H7 HALOGEN bulbs in the meanwhile to use in those projectors and still have a nice light output, and have HID ready headlights. Its a good option if you can't afford a full retrofit all at once. This is what you can expect http://www.6gc.net/forums/index.php?showtopic=50849 . ![]() -remy This post has been edited by Rayme: Sep 24, 2007 - 2:16 PM -------------------- ![]() -Rémy 02 SiR, 08 250R |
Sep 10, 2007 - 9:46 AM
Enthusiast ![]() ![]() ![]() ![]() Joined Nov 7, '06 From Lawrence IN, 46226 Currently Offline Reputation: 17 (100%) |
sounds like a good deal. if i had the money, i would deff hit this deal. g/l w/ the service.
Sep 10, 2007 - 11:46 AM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Oct 28, '02 From Europe, Lithuania Currently Offline Reputation: 8 (100%) |
All you need now - is nice shroud around the Projector - witch to make - is a tricky part
-------------------- Ex celica owner - just a guy from other side of the pond...
Full custom Projects from restoration to performance builds <<<<<< DCw / JDMart >>>>>>> |
Sep 10, 2007 - 12:04 PM
![]() Enthusiast ![]() ![]() Joined Dec 3, '04 From torrance, ca Currently Offline Reputation: 0 (0%) |
You can always throw on BMW shrouds if you're too lazy lol. $650 for a projector retrofit and oem hids and ballast is a steal. Does this apply towards other cars too?
Sep 10, 2007 - 2:19 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 29, '05 From So-Cal Currently Offline Reputation: 12 (100%) |
can these projectors functions as well as any of the newer luxury cars that have projectors that can readjust the lighting level accordingly to the situation...such as the BMWs?? hope this makes sense.
Sep 10, 2007 - 5:09 PM
QUOTE(chacha @ Sep 10, 2007 - 4:19 PM) [snapback]594919[/snapback] can these projectors functions as well as any of the newer luxury cars that have projectors that can readjust the lighting level accordingly to the situation...such as the BMWs?? hope this makes sense. I tried a few shroud option but I didn't find anything that looked as good as naked. however, if you like whats on the picture its what you will get, I personally thinl it look descent. And a shourd would add probably like 150$ on top of it. There is no level adjustment, you set it up properly and that's it. Its not required, Acura TSX have fixed level HID's for example. And these projectors are actual units found on inifity fx35/45. I'm very flexible, if you want a retrofit and already have your own ballast+bulbs I can shed off 150$. -------------------- ![]() -Rémy 02 SiR, 08 250R |
Sep 10, 2007 - 8:27 PM
Enthusiast ![]() Joined Nov 29, '06 From South Florida Currently Offline Reputation: 0 (0%) |
for shrouds...i kno a ez fix can be drip covers from electric stoves, they run about $10 for a set, and pretty much modify to fit
Sep 10, 2007 - 10:13 PM
QUOTE(baddisintegra @ Sep 10, 2007 - 9:27 PM) [snapback]595020[/snapback] for shrouds...i kno a ez fix can be drip covers from electric stoves, they run about $10 for a set, and pretty much modify to fit ![]() that looks fu**ing retarded -------------------- ![]() |
Sep 11, 2007 - 2:07 AM
QUOTE(Rayme @ Sep 10, 2007 - 5:09 PM) [snapback]594960[/snapback] QUOTE(chacha @ Sep 10, 2007 - 4:19 PM) [snapback]594919[/snapback] can these projectors functions as well as any of the newer luxury cars that have projectors that can readjust the lighting level accordingly to the situation...such as the BMWs?? hope this makes sense. I tried a few shroud option but I didn't find anything that looked as good as naked. however, if you like whats on the picture its what you will get, I personally thinl it look descent. And a shourd would add probably like 150$ on top of it. There is no level adjustment, you set it up properly and that's it. Its not required, Acura TSX have fixed level HID's for example. And these projectors are actual units found on inifity fx35/45. I'm very flexible, if you want a retrofit and already have your own ballast+bulbs I can shed off 150$. so putting in the Acura TSX projectors that has that auto fix level thing is no differ or problem for you to do right? how much for the acura tsx if you can get them? including with the labor... |
Sep 11, 2007 - 3:02 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jul 3, '04 From Yakima, WA Currently Offline Reputation: 1 (100%) |
QUOTE(dustin15brown @ Sep 10, 2007 - 8:13 PM) [snapback]595039[/snapback] QUOTE(baddisintegra @ Sep 10, 2007 - 9:27 PM) [snapback]595020[/snapback] for shrouds...i kno a ez fix can be drip covers from electric stoves, they run about $10 for a set, and pretty much modify to fit ![]() that looks fu**ing retarded hahah...
-------------------- the 1/4 doesnt have patience for a ST.... so we make them ST-T's so atleast we'll sound good going slow.
Sep 11, 2007 - 6:02 AM
QUOTE(chacha @ Sep 11, 2007 - 3:07 AM) [snapback]595093[/snapback] QUOTE(Rayme @ Sep 10, 2007 - 5:09 PM) [snapback]594960[/snapback] QUOTE(chacha @ Sep 10, 2007 - 4:19 PM) [snapback]594919[/snapback] can these projectors functions as well as any of the newer luxury cars that have projectors that can readjust the lighting level accordingly to the situation...such as the BMWs?? hope this makes sense. I tried a few shroud option but I didn't find anything that looked as good as naked. however, if you like whats on the picture its what you will get, I personally thinl it look descent. And a shourd would add probably like 150$ on top of it. There is no level adjustment, you set it up properly and that's it. Its not required, Acura TSX have fixed level HID's for example. And these projectors are actual units found on inifity fx35/45. I'm very flexible, if you want a retrofit and already have your own ballast+bulbs I can shed off 150$. so putting in the Acura TSX projectors that has that auto fix level thing is no differ or problem for you to do right? how much for the acura tsx if you can get them? including with the labor... Acura TSX WILL require shrouds, and you will loose efficient high beam because clear lights over your high beams looks like 2 flashlights. -------------------- ![]() -Rémy 02 SiR, 08 250R |
Sep 12, 2007 - 8:14 PM
Enthusiast ![]() ![]() Joined Aug 21, '06 From washington Currently Offline Reputation: 4 (100%) |
Payment has been sent and i cant wait to get them in.
Sep 21, 2007 - 7:36 PM
free bump
Sep 24, 2007 - 2:17 PM
New option :
If you guys want ONLY the retrofit (4 lens + bi-xenon projectors) and use your own HID hardware, I can do the retrofit for 300$ + shipping. You can mod H7 HALOGEN bulbs in the meanwhile to use in those projectors and still have a nice light output, and have HID ready headlights. Its a good option if you can't afford a full retrofit all at once. -------------------- ![]() -Rémy 02 SiR, 08 250R |
Sep 24, 2007 - 3:39 PM
Enthusiast Joined Apr 26, '07 From Fort Lauderdale, FL Currently Offline Reputation: 0 (0%) |
Oh man, if my celica would be my main car and the only car i would definatlly do so.
Sep 24, 2007 - 6:04 PM
Enthusiast ![]() ![]() Joined Jan 8, '07 From Charlotte, NC Currently Offline Reputation: 7 (100%) |
the projectors take d2s bulbs right?
what is the turn around time? i want to do this, but my celica is my daily driver, and i would have to drive without lights... This post has been edited by Lovo: Sep 24, 2007 - 6:06 PM -------------------- ![]() |
Sep 24, 2007 - 6:57 PM
I'm goign to get ahold of low beams so I can do it and ship them to whoever wants them, then they can return their originals to me. It's goign to take a couple weeks from now but I think it's going to make it easier for everyone.
In the meanwhile, if any can go without headlights for a couple weeks I'm still available. -------------------- ![]() -Rémy 02 SiR, 08 250R |
| Lo-Fi Version | Time is now: December 14th, 2025 - 4:42 PM |
