> Question for those that bought a 3sgte (NOT a clip), If you bought a clpi this doesn't relate to you
post Sep 12, 2007 - 4:29 PM
Rayme
Joined Feb 18, '06
From NB, Canada
I see alot of engine swap around and most of them miss the air intake tubing and the maf sensor...well of course you need that, so that an extra part one need to buy when buying an engine instead of a clip.
My question is there alot more that there is missing..I know the 5sfe uses component on the firewall like the ignitor and the map sensor..is there any of those "not on the engine component" that might be missing?
I see most engine comes with the harness and ecu, that's not a real problem so far..
I was just wondering about the usual "missing peices" in engine swap...thanks!
-Rémy
02 SiR, 08 250R
post Sep 12, 2007 - 5:01 PM
burnyd
Joined Oct 13, '06
From Pittsburgh
are you refering to the afm? You do need that depending on what gen 3sgte we are referring to. Yes you you need the map sensor and ignitor also.
In almost all cases you need to get an entire clip. Besides you will need to source other parts... even with an mr2/alltrac you still ned a JDM coil.
Clips are pretty inexpensive anyways now.... did you purchase one or are you shopping around?
This post has been edited by burnyd: Sep 12, 2007 - 5:02 PM
post Sep 12, 2007 - 5:13 PM
jcbass7
Joined Apr 20, '06
From Florida
i bought my engine off a guy who bought it straight off ebay. it had everything i needed and more for the swap.
post Sep 12, 2007 - 5:49 PM
Rayme
Joined Feb 18, '06
From NB, Canada
Im shopping around, for now..and I dont have a garage so a clip is out of the idea... I'm just looking for the parts that I will eventually need.
-Rémy
02 SiR, 08 250R
post Sep 12, 2007 - 6:08 PM
Blakout16
Joined Jul 3, '04
From Yakima, WA
if you dont have a garage... how do u plan on storing the engine?
post Sep 12, 2007 - 6:13 PM
Rayme
Joined Feb 18, '06
From NB, Canada
-Rémy
02 SiR, 08 250R
post Sep 12, 2007 - 6:16 PM
Blakout16
Joined Jul 3, '04
From Yakima, WA
so why cant a clip fit in there? ;D
post Sep 12, 2007 - 6:54 PM
toyotacrazy
Joined Mar 4, '06
From Ohio
QUOTE(Rayme @ Sep 12, 2007 - 4:29 PM) [snapback]595506[/snapback]
Mine was missing the boost pressure sensor. Thats it. I picked on up on ebay for $30 shipped. I think that was a lucky find though
post Sep 14, 2007 - 7:57 AM
jcbass7
Joined Apr 20, '06
From Florida
i don't have a garage, i did the whole swap out in the driveway.
post Sep 14, 2007 - 11:14 AM
Silver94CelicaOw...
Joined Oct 13, '02
From Blairstown, New Jersey
Especially with a 2nd gen motor, I would get a full clip since finding things like the coil/ignitor, AFM, MAP sensor, VSV, etc will just be a pain.
I stumbled upon a VERY rare situation when I bought my 3rd gen 3SGTE and it came with absolutely everything, so I didn't need a clip. But those situations are rare, and for the most part a clip is the way to go.
post Sep 14, 2007 - 7:33 PM
jcbass7
Joined Apr 20, '06
From Florida
I agree with corey^ a clip is a much safer and easier way to go since you remove it from the clip and learn all the steps etc, but if you go with buying an engine set, just make sure it has everything you need and if it does.. should be fine tongue.gif
Lo-Fi Version Time is now: February 17th, 2025 - 3:45 PM
