ST 185 - ST205 |
ST 185 - ST205 |
Sep 13, 2007 - 12:05 AM |
Enthusiast Joined Apr 28, '07 From Venezuela Currently Offline Reputation: 0 (0%) |
ST185 3SGTE engine have the same motor mount that the ST205 3SGTE engine????
If i buy ST185 3SGTE will fit on my ST202? or i must buy ST205 3SGTE? |
Sep 13, 2007 - 12:08 AM |
Enthusiast Joined Apr 2, '07 From Great Western Plateau Currently Offline Reputation: 9 (100%) |
all s series have the same mount..st185 will pop right in.
-------------------- 98% completion --- aaRon |
Sep 13, 2007 - 12:11 AM |
yey!!! .... Thx!
Sep 13, 2007 - 10:03 PM |
Enthusiast Joined Feb 14, '07 From Provo, UT USA Currently Offline Reputation: 25 (100%) |
QUOTE(fran @ Sep 12, 2007 - 11:11 PM) [snapback]595654[/snapback] yey!!! .... Thx! the 3rd gen 3sgte (st205) has more horse than 2nd gen (st185) but is more expensive. you could also put in the 3s from an mr2 turbo but you would need to relocate a few things. -------------------- |
Sep 13, 2007 - 10:14 PM |
hold on guys...
if you want to put a st185 or st205 in your GT then you would use you existing GT mounts (3 are on the tranny) and you will use your GT tranny, not the 185 or 205 tranny (it's 4 wheel drive). so the quick answer is NO. The 185 and 205 tranny mounts/brackets are different. If you plan to swap from a GT to having a 185 or 205 motor, then use your GT mounts. -------------------- |
Sep 13, 2007 - 10:36 PM |
i will use my GT tranny with my GT gearbox... i dont must change the motor mounts true???
i just must put the engine under the hood and all will fit nice, thats rigth? same motor mounts of my 3SFE.. |
Sep 13, 2007 - 10:47 PM |
QUOTE(Batman722 @ Sep 14, 2007 - 11:14 AM) [snapback]595894[/snapback] hold on guys... if you want to put a st185 or st205 in your GT then you would use you existing GT mounts (3 are on the tranny) and you will use your GT tranny, not the 185 or 205 tranny (it's 4 wheel drive). so the quick answer is NO. The 185 and 205 tranny mounts/brackets are different. If you plan to swap from a GT to having a 185 or 205 motor, then use your GT mounts. batman im not sure i follow you here, he never asked for which tranny to use he was only asking if the 3sgte fit in his car, and the answer is YES..but i do see where you're coming from. to fran, yes the motor will fit under ur hood just fine...my advice is to get the gt4 bonnet and bumper to allow more air to flow through, or go with a FMIC. -------------------- 98% completion --- aaRon |
Sep 13, 2007 - 10:58 PM |
yes i will buy front bumper and hood of the GT4, wath ever soon or later i will equip a FMIC
I was thinking to get some 300-350 HP with the 3SGTE... CT26 can handle 20 PSI of boost? Plus add 50HP with nitrous then up to 400HP, the 3SGTE comes with forged internal. do you think that i will blow up the engine? ^^ |
Sep 14, 2007 - 1:59 AM |
QUOTE(fran @ Sep 13, 2007 - 9:58 PM) [snapback]595910[/snapback] yes i will buy front bumper and hood of the GT4, wath ever soon or later i will equip a FMIC I was thinking to get some 300-350 HP with the 3SGTE... CT26 can handle 20 PSI of boost? Plus add 50HP with nitrous then up to 400HP, the 3SGTE comes with forged internal. do you think that i will blow up the engine? ^^ you won't get that much HP with just a 3sgte drop in. they are rated around 240-250 hp stock IIRC don't quote me. you would have to do a lot of mods to get it to 400 hp. more that just NOS. i think itchy b has his at about 320 hp and he has a huge A turbo on his as well as a lot of other mods. -------------------- |
Sep 14, 2007 - 5:53 AM |
Enthusiast Joined Aug 29, '02 From Lake Orion, MI Currently Offline Reputation: 6 (100%) |
I need the big ones...... two of 'em.... and Harry... I need them by tonight.....
But seriously My personal goal with my 3rd GEN 3SGTE has always been 300 HP at the wheels with nothing more than some mild (IMHO) engine work and a boost controller 400 "appears" to require a larger turbo, maybe some cams, and 3rd party engine management I'm also not sure why everyone wants to drop the W/A intercooler... I find the idea of a uber short air track to be most excellent -------------------- -Mike
mjcoury@gmail.com Team Reynolds Style Celica Blog Celica Wiki It will take him a moment to realize that he's about to make a 180 degree turn at speed, but you will be ready for it. Brace for the g's, and fast heel-toe work. |
Sep 14, 2007 - 12:36 PM |
the internal are good forged? or do you think that they must be replaced for new ones?
i think that with some cam work, new pulleys, bigger TB, bigger turbo and FMIC, then easy go up to 300HP what its the biggest turbo that anyone put on a 3SGTE?... later the problem when you got a big turbo its turbo lag!... |
Sep 14, 2007 - 1:49 PM |
Enthusiast Joined Oct 5, '03 From South TX. Currently Offline Reputation: 14 (100%) |
the stock internals dont handle much power(pistons break ringlands way too easy), i also wouldn't push the ct26 past 16psi.....thats with meth injection, and other supporting mods.
get on mr2oc.com to see what you need to push that power. |
Sep 14, 2007 - 7:33 PM |
ok! ok! nice xD! then ill go to mr2oc.com...
Thx 95celgt |
Sep 14, 2007 - 7:47 PM |
No prob, good luck on that build!
Sep 15, 2007 - 6:55 PM |
yeeeeah! i whant to ensamble it without too many problems!... i was thinking about the ECU wiring!. That part will be the most difficult, wath do you think!?
Sep 15, 2007 - 7:54 PM |
once you get ALL the parts necessary, i'd send the harnesses to Dr.Tweak, the price is worth it, no guessing.
Sep 16, 2007 - 9:21 AM |
QUOTE(fran @ Sep 14, 2007 - 11:58 AM) [snapback]595910[/snapback] yes i will buy front bumper and hood of the GT4, wath ever soon or later i will equip a FMIC I was thinking to get some 300-350 HP with the 3SGTE... CT26 can handle 20 PSI of boost? Plus add 50HP with nitrous then up to 400HP, the 3SGTE comes with forged internal. do you think that i will blow up the engine? ^^ depends on what spec is the clip ur getting..jdm t26s are ceramic and can boost up to 28psi..although i dont recommend going anywhere above 18psi, but a guy had his all the way to 28. with aftermarket ecu, FMIC, exhaust you can boost this little beauty to 18psi--->280hp, thats a pretty good setup considering no mod were done to it. A mapable boost controller can proabbly take it to 24psi..but power would be lost. if you wanna take it to 400..then thats another story. -------------------- 98% completion --- aaRon |
Lo-Fi Version | Time is now: November 25th, 2024 - 9:30 AM |
