> The dots on tires, what are these
post Aug 8, 2003 - 4:55 AM
Andason
Joined Jun 26, '03
From Wisconsin
What are the colored dots on my tires and why are they on there? They are only on two of the rims.
i am awesome
post Aug 8, 2003 - 1:05 PM
Do you have any pictures of what you're describing?
post Aug 8, 2003 - 2:21 PM
forkee
Joined Nov 13, '02
From So Cal
i had a red and yellow dot on the tires when they were brand new but they came off eventually..... tongue.gif
post Aug 9, 2003 - 12:56 PM
silvasurfa
Joined Jun 15, '03
From Folkestone, Kent, ENGLAND
theyre just to help the tyre manufacturers out, basically a sort of way of categorising the tyres when theyre on the rack
they eventually wear off and are a good thing to look out for when buying second hand wheel/tyres, if theyre still there youre onto a winner! wink.gif
post Aug 29, 2003 - 1:19 PM
Turbotone
Joined Aug 19, '03
From S/East. UK
If the dots your talking about are either red or yellow,
and appear on the side wall.
the dot 'should' be aligned up with the vavle. it is the manufactures indication of ballance taking into consideration the valve. This i guess would be the same in the states as it is in the uk
HTH
This post has been edited by Turbotone: Aug 29, 2003 - 1:21 PM
....'SilverMachine'.... Toyota Celica GT-Four ST205 "Hybrid"
for more info visit:- http://www.jordanracing.moonfruit.com
post Aug 31, 2003 - 9:32 PM
95STCelica
Joined Oct 12, '02
From New Jersey
yeah i had those when i got my tires from Wheelmax.
post Sep 5, 2003 - 6:22 AM
62ndXAssAssin
Joined May 28, '03
yeah they're just a way of showing the high point and the low point of the tire. I learned this stuff cus i mount tires for a living. Turbotone was correct in saying the tire mounter has to line up the dot (the yellow one) with the valve. Then when you balance the tire u get a better and more accurate reading on the balncer. That's all it is, it comes off over time.
Lo-Fi Version Time is now: January 17th, 2025 - 2:46 PM
