![]() Enthusiast ![]() ![]() ![]() ![]() Joined Nov 27, '02 From Derry,NH USA Currently Offline Reputation: 9 (100%) ![]() |
I just got my car back after doing a head gasket,valve seals,all new belts and a water pump so I figured I was set til my appointment to also replace my oil pan gasket in a few days...driving home after getting off a dirt road I hear this weird noise everytime I turned left...a high pitched squeaking/grinding sound...and also sometimes when I was straight and coming to a stop....
Would this be a wheel bearing issue? -------------------- ![]() |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 28, '05 From Redondo Beach, CA Currently Offline Reputation: 86 (100%) ![]() |
signs of a bad bearing
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 29, '05 From So-Cal Currently Offline Reputation: 12 (100%) ![]() |
or that your brakes are almost out and that it is lose and thus when you turn it is rubbing on the rotors..
I literally just replaced my entire brake system like a month ago,the pads are still wicked thick and my rotors aren't even scratched.
![]() Enthusiast ![]() Joined Apr 16, '06 From Melbourne, Australia Currently Offline Reputation: 0 (0%) ![]() |
post the sound up if you can, cause i had a similar problem a while ago
Lo-Fi Version | Time is now: February 22nd, 2025 - 6:59 PM |
