![]() Enthusiast ![]() ![]() ![]() ![]() Joined Jun 10, '03 From FL Currently Offline Reputation: 0 (0%) ![]() |
Ok, so when on lo for long periods of time my A/c light starts blinking on the console and the air stops pumping out cool. Then If i turn it on hi it kicks in again. Do i need new frion? (sp) But it works when on Hi. Any help would be great.
ps. could it also be because i was running at extremely slow speeds? ie. rain and the roads flooded. Because it has never happened before. |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 30, '02 From Anaheim, CA Currently Offline Reputation: 0 (0%) ![]() |
i have never heard of that before
was your engine temperature normal or was it getting hot? i know that at certain times the ac compressor is turned off when the coolant is cold enough. it then turns back on when it warms up again it seams like you might have a short in the switch or wiring somewhere -------------------- 1994 Celica GT4 WRC Edition
@gt4.wrc on Instagram |
No temp was in the middle. ARG
Enthusiast Joined Jul 23, '03 From USA Currently Offline Reputation: 0 (0%) ![]() |
I guess A/C compressor burned. Check A/C compressor leaking oil. When compressor broke, my friend A/C light blink and has enough frion on AE86. check A/C belt lose check enough frion, may be leaking frion somewhere. check compressor whether A/C sometime engage sound. |
![]() Enthusiast ![]() ![]() ![]() Joined Aug 30, '02 From North Carolina Currently Offline Reputation: 0 (0%) ![]() |
The road I was on flooded one night and i didnt see it and hit it about 60 or so and the car dived in the front and the AC light started to do that and did it for about a min and then it stopped but, thats the only time I have ever ahd it to happen!
-------------------- 99 Toyota Tacoma
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jun 26, '03 From Wisconsin Currently Offline Reputation: 0 (0%) ![]() |
I have a 98 GT and my AC light is blinking too, I doesn't blow out any cold air. Any ideas? Pre-owned won't cover this so I'm waiting till next summer. POS AC. Toyota Celica's need to learn how to make AC work. I hear of this problem a lot, and had the same thing on my 5GC but without this annoying blinking light.
-------------------- i am awesome
![]() This post has been edited by blkGT: Sep 21, 2003 - 2:51 PM |
What exactly does that do? -------------------- i am awesome
makes it work. lol
i have no technical explanation. But i think the compressor doesnt have enuff power so when u run it full blast it gains some back. |
I dont think so, mine did it a few times in one day, but hasnt done it since and that was august 8. and it blows as cold as ever |
turning something off then back on again doesnt make it work better...
i tried that too i was just saying what happened to me |
I dont think its the fact of turning it off and back on, its when u run it full blast and kinda get the generator "warmed up" that it wont blink. Just my 2 cents tho
Enthusiast ![]() Joined Jan 1, '03 From CT Currently Offline Reputation: 0 (0%) ![]() |
is the A/C light in your dash or in the heat controls? If its in the heat controls it sounds like an electrical short, possible need a new switch. In the dash, no so sure probably need frion or check to make sure the compressor is working properly, there is not a whole lot to the A/C system to go wrong.
they are referring to the light on the A/C button...it blinks and then it stops blowing cold air.
i took the frion approach like you but it was no good. |
I'm guessing more then likely it's the freon. It doesn't work at any level(High, low). -------------------- i am awesome
Lo-Fi Version | Time is now: February 17th, 2025 - 1:29 PM |
