> Code 42, what does this mean?
post Sep 17, 2007 - 11:07 PM
GotToyota
Joined Apr 15, '07
From Fort Worth, TX
Today for kicks, I checked my diagnostic codes, and the only one I pulled was Code 42. I did some research and it indicates something about the speed sensor signal. What could this mean?
-Matt
post Sep 20, 2007 - 12:46 PM
GotToyota
Joined Apr 15, '07
From Fort Worth, TX
Anyone?
post Sep 20, 2007 - 1:22 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
does your speedo work?
it could be the wire to the ecu corroded or shorted
post Sep 20, 2007 - 1:30 PM
GotToyota
Joined Apr 15, '07
From Fort Worth, TX
QUOTE(stephen_lee @ Sep 20, 2007 - 1:22 PM) [snapback]597616[/snapback]
Yep, speedo works just fine, doesn't stutter or anything.
-Matt
post Sep 20, 2007 - 2:36 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
so the signal IS there, but isn't getting to the ECU, i think. so check your ecu plugs.. i belive its the plug closest to the engine bay.. just unplug htem all, then plug them back in. if that doesn't help, start looking for something wrong with the speed sensor wire..
post Sep 21, 2007 - 7:56 AM
GotToyota
Joined Apr 15, '07
From Fort Worth, TX
How do I access the ECU?
-Matt
post Sep 21, 2007 - 3:36 PM
GriffGirl
Joined Feb 7, '07
From Portland, Oregon
To the best of my knowledge, the speed sensor is actually what is also known as the wheel speed sensor, which controls the ABS. Do your brakes behave erratically, or is your ABS light on? If your brakes pulsate at lower speeds or grind and pulsate simultaneously, combined with that code, it could be your ABS failing.
Lo-Fi Version Time is now: December 1st, 2024 - 8:41 PM
