> F.S. 2 10inch DVC subs, box and amp, CHEAP!!!!!!
post Sep 24, 2007 - 1:43 PM
massbrandon
Joined Mar 6, '06
From massachusetts
Hey you guys I am selling my sound system. The subs are the same type that I have in my car these are dual voice coil. Let me tell you for the price they sound great. The specs will be listed below. The box is a dual ten inch Q Logic box. This is the best box that I have used to date. The amp is a Panasonic 360 watt amp. The specs are listed below. I am going to ask 50 bucks shipped (OBO) per speaker (US), the amp is 50 bucks (OBO), the box is 80 shipped (OBO).
pic of the subs
* MA Audio MA101-XQ High Performance Sub
* Power Handling Capabilities
* 250 Watts RMS Minimum to 500 Watts
* Dual 4-Ohm Voice Coil
* 50 Oz. Magnet
* Mounting Depth: 5.6”
* Mounting Diameter: 9.2”
* Optimum Vented Box: 1.75 Cu/Ft
* Round Port Diameter: 4” X 9”
* Square Port Area: 2.5” X 6” X 11.5”
* Optimum Sealed Box: 1 Cu/Ft
* Tuning @ 40Hz
* Full 2 Year Warranty
* Manufacturer’s Suggested Retail $99.99
the amp
RMS power 13.8VDC
Power 4 Ohms............................... 120W 2
Power 2 Ohms............................... 200W 2
Bridged power 4 Ohms ................. 360W 1
Minimum speaker impedance.............. 2 Ohms
THD distortion....................................... 0.08%
IMD distortion........................................ 0.08%
Frequency response............................. 20 Hz to 20 KHz
Input sensitivity..................................... 200mV to 6V
Input impedance ................................... 15K
Signal-to-noise ratio............................. 90dB
Channel separation............................... 50dB
This post has been edited by massbrandon: Sep 24, 2007 - 2:36 PM
post Sep 24, 2007 - 2:25 PM
massbrandon
Joined Mar 6, '06
From massachusetts
I should also add that all of the necessary wiring will come with this.
post Sep 24, 2007 - 3:59 PM
goferris
Joined Feb 14, '07
From Provo, UT USA
QUOTE(massbrandon @ Sep 24, 2007 - 1:25 PM) [snapback]598684[/snapback]
do you have a packaged deal?
semi interested
post Sep 24, 2007 - 4:04 PM
massbrandon
Joined Mar 6, '06
From massachusetts
Yeah I could work that out. The two subs, amp, box, and all wiring. Would have to be a couple different packages but yeah I could make it work. Make an offer if you are interested. I have to get this stuff out my my buddy's room by Wednesday.
This post has been edited by massbrandon: Sep 24, 2007 - 4:04 PM
post Sep 25, 2007 - 1:06 PM
massbrandon
Joined Mar 6, '06
From massachusetts
bump
post Sep 25, 2007 - 4:34 PM
pittfirefighter
Joined Oct 10, '06
From Greensburg,PA
you have a pic of an insignia amp (best buy) but have it listed as panasonic?
Breaking Axles...
post Sep 25, 2007 - 4:58 PM
massbrandon
Joined Mar 6, '06
From massachusetts
Yeah its an Insignia amp. Its actually made by Panasonic.
post Sep 26, 2007 - 4:30 PM
massbrandon
Joined Mar 6, '06
From massachusetts
bump
post Oct 20, 2007 - 2:33 PM
massbrandon
Joined Mar 6, '06
From massachusetts
back from the dead bump
Lo-Fi Version Time is now: February 23rd, 2025 - 7:04 PM
