> Got the belt on, it started smoking..., now i need a tensioner?!? SIGH.
post Sep 28, 2007 - 8:16 PM
easternpiro1
Joined Feb 1, '05
From Charlotte NC
whats up guys... having yet another issue with this coupe i have. To my SURPRISE it over heated earlier today on my way to get the oil changed, when i finally realized what was going on i put some water in it and put 4 fresh quarts of oil in it and was on my way. car was fine until tonight here's what happened.
doing about 65 on highway
hear a slight pop or bump sound
car looses mechanical power
car will not start (it spins as if it wants to start but wont run dont hear any clanking noise indicating thrown rod)
checked to see if oil was under the car
I checked to see if the head gasket is blown (oil not milky nor does it have metal flakes in it)
checked the resorvoir for the radiator
i am ABSOLUTLEY CLUELESS as to what happened.
no tools to check if the timing belt broke
Im beginning to question this car, only had it since may and there have been silly things since the day i got it... LITERALLY the day i got it.
what do you guys think may have happened?
This post has been edited by easternpiro1: Oct 3, 2007 - 10:46 PM
post Sep 28, 2007 - 9:15 PM
my guess is tbelt.
pull the distributor cap, and have someone turn it over, make sure the rotor spins. if it dont, t-belt is broken.
post Sep 29, 2007 - 9:14 AM
easternpiro1
Joined Feb 1, '05
From Charlotte NC
i was also wondering if low oil could cause it to overheat as well...too much friction in chambers?
post Sep 29, 2007 - 9:21 AM
Black2na
Joined Jul 3, '05
sounds like you did some damage. low oil would cause the motor to run hotter but at that point the bearings would have a lot of wear on them if not destroy. i say check if the t-belt broke or slipped teeth like manny said and if that is in order pull the pan and check the bearing and see if there are heavy metal fragments in the bottom. and you wouldn't hear it knock untill the car actully starts. least in my experence.
2002 Supercharged IS300
post Sep 29, 2007 - 10:41 AM
easternpiro1
Joined Feb 1, '05
From Charlotte NC
QUOTE(Black2na @ Sep 29, 2007 - 9:21 AM) [snapback]600039[/snapback]
metal fragments? ok. i remember when i blew my original 7a (waay back) i threw a rod and it had metal shavings in the oil. i checked the oil didnt see any metal flakes. does that make much difference?
post Sep 29, 2007 - 10:48 AM
Black2na
Joined Jul 3, '05
well just cause you checked it doesn't mean there arn't shavings in the pan and from the sounds of it you did some damage to them doesn't take much to do so takes mabye 40 mins to remove the pan and its a piece of mind if you find nothing. but like manny said check the T-belt
post Sep 29, 2007 - 6:19 PM
easternpiro1
Joined Feb 1, '05
From Charlotte NC
ok finally got the car towed from off of the highway. tried to start it again. no go. my friend says it spins to fast indicating that there may be no compression. thrown rod you guys think? we didnt have time to take it apart will get on it tomorrow.
post Sep 29, 2007 - 6:46 PM
TRD_GT
Joined Jul 12, '07
From London,Great Britain
u could always try and see if you have any oil pressure..if your pressure is low or even gone then the oil pump must be out..if u were running low oil to begin with and ur car conked out..chances are your oil pump was working over time to get what little oil it had in the engine to flow round..and since it was doing that it probably burnt itself out..the car is probably refusing to start because your oil pump and pressure is non-existant..so the cpu doesn't allow the car to start..
but hey..thats my opinion..
post Sep 29, 2007 - 7:03 PM
how low was the oil? and why didnt you keep it toped off?
kind of sounds like you threw a rod from lack of oil. get some tools and find out for sure.
post Sep 29, 2007 - 8:14 PM
alltracman78
Joined Aug 9, '06
From Ma
QUOTE(easternpiro1 @ Sep 29, 2007 - 6:19 PM) [snapback]600141[/snapback]
Spins fast = broken timing belt.
If you threw a rod you'd know.
Go check that before you ask any more questions.
post Sep 29, 2007 - 8:50 PM
easternpiro1
Joined Feb 1, '05
From Charlotte NC
QUOTE(lagos @ Sep 29, 2007 - 7:03 PM) [snapback]600146[/snapback]
hey lagos! long time bro!
when i checked at the oil earlier it was half. had to wait till friday to get oil changed. when it overheated it was dry which didnt make sense to me. no oil light. did not realize the oil burned so quick i knew i had a small burn but only when the car sat for a while.
post Sep 30, 2007 - 4:26 PM
easternpiro1
Joined Feb 1, '05
From Charlotte NC
found out that it was the timing belt (thank GOD) the only problem now is getting the pulley (i think the water pump pulley) that sits right above the lower timing belt pulley off... how do you squeeze that S.O.B. off?!? we jacked up the motor still no luck. is there something im missing?
is the pulley 2 piece as in come apart? it looks like it but not sure kindasad.gif
anybody know?
post Sep 30, 2007 - 7:38 PM
trdss111
Joined Jun 30, '07
From Ireland
QUOTE(easternpiro1 @ Sep 30, 2007 - 4:26 PM) [snapback]600294[/snapback]
anybody know?
timing belt can mean big money.
post Sep 30, 2007 - 8:10 PM
jcaron9gt4
Joined Feb 26, '07
From Boston, MA
QUOTE(trdss111 @ Sep 30, 2007 - 8:38 PM) [snapback]600329[/snapback]
anybody know?
not if you do it yourself
post Sep 30, 2007 - 9:40 PM
easternpiro1
Joined Feb 1, '05
From Charlotte NC
thats right! jcaron..we are trying to do it ourself but i cant figure out how to get that pulley off! it hits the wheelwell of the car. sure beats 400 bucks!
post Sep 30, 2007 - 9:50 PM
it helps if you lower that side of the engine abit.
+1 for me! =)
post Sep 30, 2007 - 9:57 PM
dont you still have your 3s? why dont yo just swap that into your car. it would all be plug and play.
post Sep 30, 2007 - 10:17 PM
easternpiro1
Joined Feb 1, '05
From Charlotte NC
QUOTE(lagos @ Sep 30, 2007 - 9:57 PM) [snapback]600376[/snapback]
yeah, i do, but alot of things are messed up and need switching out like axles (passengerside broken) and i need pulleys for the 3s. also had custom a/c lines. will take it back to tweak sometime next year.
QUOTE(presure2 @ Sep 30, 2007 - 9:50 PM) [snapback]600375[/snapback]
+1 for me! =)
you the man manny! but, we tried to lower the motor, how? the way it was sitting it went back to its original position
This post has been edited by easternpiro1: Sep 30, 2007 - 10:16 PM
post Sep 30, 2007 - 10:55 PM
take the front and rear mount out and support the engine either from the top or bottom.
post Sep 30, 2007 - 11:01 PM
easternpiro1
Joined Feb 1, '05
From Charlotte NC
QUOTE(Batman722 @ Sep 30, 2007 - 10:55 PM) [snapback]600385[/snapback]
ok. will give it a try tomorrow. is there another way?
Lo-Fi Version Time is now: December 2nd, 2024 - 9:03 AM
