4 Pages V  < 1 2 3 4 >
> cams are here, webcams - pics and dyno pics yay
post Dec 2, 2007 - 8:12 AM
Kadett
Joined Mar 17, '05
From The Netherlands
QUOTE(Rusty @ Dec 2, 2007 - 6:21 AM) [snapback]618895[/snapback]
hmm, how much work you done on it (intake & filter, full exhaust, cams)
how much are you losing through the gearbox?
I lose 10kw, but I still hold 147HP(with just an air filter)
good to compare when you turbo it.
Little bit unfair to compare a 3S-GE to a 5S-FE
post Dec 2, 2007 - 9:29 AM
QUOTE(Batman722 @ Dec 2, 2007 - 12:23 AM) [snapback]618885[/snapback]
ok here's the pics.
the cams
and my nose
now the real info
now my motor has 156K miles on it and my compression was low, but consistant.
here's a comparison was another 5s, 1998 51K miles on it
and some #s info
and the INFO
my 5s topped out at 123whp and 126ft/lbs of torque.
on the 1998 stock 5s (intake) at 4700 RPMs it doesn't make any more power, it drops hp like a rock. My 1995 156K 5s continues to make hp. I peaked out close to redline and CONTINUED TO MAKE POWER until then. So at redline (about 6000 RPMs) I had about 123hp while the stock had The stock 5s 103hp. As for torque, the 98 drops off at 4700 and mine continued hold out longer. I had 110ft/lbs of torque and the stock 98 had 92ft/lbs.
The bottom line is I didn't dyno my car before the cams were installed so I don't know exactly were I'm starting from. From the research I've done they seem to average around 105-110hp to the wheels. If my motor was in peak condition like the 98 then I have gained about 10hp to the wheels. The important thing here is my car now holds the power later in the RPM band and where any other stock 5s drops off, my car continues to make power, right to redline.
now when I turbo...
dustin, heres a better view for you and the guys.
this is my run #8, when the car was fully warmed up and heated like yours was.
the red line is a stock 98 5sfe with a injen short ram intake, the blue is dustins 95 with cams.
again guys, i really cant emphisise how much of a diffrence these cams made in his powerband.
webcams did a very good job on them.
these cams are perfect for th n/a 5s. keeps 99% of the low end we love, and makes a HUGE diffrence up top, where the 5s normally falls on its face.
now that we've found at least one place that can do cams for the 5s sucsessfully, im working on getting a set from another company that can do them as well, only the ones im having done will be done with the 5sfte in mind.
if that goes well, we "may" be able to set up a group buy on them, both for n/a and turbo 5s'
post Dec 2, 2007 - 9:38 AM
Rayme
Joined Feb 18, '06
From NB, Canada
thats great, not much top HP gain but you gain more usable power in the end.
-Rémy
02 SiR, 08 250R
post Dec 2, 2007 - 1:40 PM
QUOTE(Rayme @ Dec 2, 2007 - 9:38 AM) [snapback]618952[/snapback]
He gained 20hp. Thats A LOT for an NA 4cly motor.
post Dec 2, 2007 - 8:07 PM
jcbass7
Joined Apr 20, '06
From Florida
nice stuff dustin!
post Dec 2, 2007 - 9:49 PM
Rayme
Joined Feb 18, '06
From NB, Canada
QUOTE(lagos @ Dec 2, 2007 - 2:40 PM) [snapback]619002[/snapback]
heyy I know I say top (or peak), not insulting the guy!
-Rémy
02 SiR, 08 250R
post Dec 3, 2007 - 12:27 AM
Rusty
Joined Nov 5, '07
From New Zealand
Ohh I meant this dyno and compare when he turbo's it
post Dec 3, 2007 - 1:23 AM
6strngs
Joined May 12, '06
From Wilmington, NC
QUOTE(presure2 @ Dec 2, 2007 - 6:29 AM) [snapback]618948[/snapback]
ok, that dyno chart makes it look a lot better. And I'm def. interested in some cams, the only thing stopping me from the web cams is the price. they are something like $650 aren't they?
post Dec 3, 2007 - 9:53 AM
jcbass7
Joined Apr 20, '06
From Florida
650 for an addition to the power curve like that, if i had my coupe still (5s) id be installing those right now!
post Dec 3, 2007 - 11:02 AM
^^ that's a great comparison there Manny. That does show a clearer view of the curves and the shift/gians in power. From 4000rpms on, I have any 5s beat hands down.
post Dec 3, 2007 - 12:08 PM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
turn the boost up! biggrin.gif nice gains man. thats some good power for an NA 5s.
post Dec 3, 2007 - 12:10 PM
6strings:
yup, ~ 650 for the pair.
in comparison, a set of cams for the 3s goes for just about the same price.
i working with another company to have a set done for the turbo 5s, they should be ~ 200$ cheaper.
post Dec 3, 2007 - 12:21 PM
jesterwr217
Joined Feb 27, '07
From cape coral/ft myers florida
are there any for the 7a?
BOOST GETS YOU LAID!!!!
post Dec 3, 2007 - 12:44 PM
LewFX
Joined Jan 28, '05
From Redondo Beach, CA
hurley is getting some for her 7a
post Dec 4, 2007 - 12:06 AM
stetsonaw
Joined Aug 3, '07
From Bellevue, Nebraska
presure2, you say there are some for a 3s. where can i get them, for a good price?
~Andy
Check out my Droid Goodies
| My Flickr
post Dec 4, 2007 - 12:32 AM
6strngs
Joined May 12, '06
From Wilmington, NC
QUOTE(presure2 @ Dec 3, 2007 - 9:10 AM) [snapback]619228[/snapback]
6strings:
the other set you are working on, are they hardwelded like the webcams or reground? I've heard that TED components cams only cost around $200 for both cams, it's a regrind though and you have to use thicker shims.
post Dec 4, 2007 - 1:04 AM
QUOTE(stetsonaw @ Dec 4, 2007 - 12:06 AM) [snapback]619446[/snapback]
hks makes them. you can get them from ebay, ats racing, etc...
post Dec 4, 2007 - 1:10 AM
Rusty
Joined Nov 5, '07
From New Zealand
what HP gain are we talking with cams in a 3S-GE? simular line veriation
post Dec 4, 2007 - 6:18 AM
QUOTE(6strngs @ Dec 4, 2007 - 1:32 AM) [snapback]619455[/snapback]
6strings:
you need to use larger shims with the webcams as well.
the colt cams are reground, and geoff includes oversized shims.
post Dec 4, 2007 - 1:26 PM
elvasoshexai
Joined May 16, '05
From Toronto, Ontario
so how do these performance cams affect driveability?
06 Civic EX
My For Sale Thread
Lo-Fi Version Time is now: November 27th, 2024 - 2:16 AM
