14 Pages V  < 1 2 3 4 5 > »
> supershannon77's new 5SFTE powered celica, NEW DYNO RESULTS PG5 285+WHP! PG6 vid added!
post Sep 30, 2007 - 9:24 PM
99GT
Joined Dec 14, '06
From MN, USA
Any concerns about boost spikes?
post Sep 30, 2007 - 9:47 PM
QUOTE(99GT @ Sep 30, 2007 - 10:24 PM) [snapback]600363[/snapback]
boost holds on this car PERFECTLY, anywhere from 5.5psi to 11psi, which is the most i can run with this wastegate spring.
gas milage on any boosted car is totally dependant on your right foot.
the more you press it, the faster the needle goes down.
highway crusing with minimal boost, i can get close to 350-400 miles out of a tank of gas in my car.
racing, it can be ALOT less than that.
lol
post Oct 1, 2007 - 7:20 AM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
awesome! glad to see it done. i wouldn't expect anything less from you guys.
post Oct 1, 2007 - 9:46 PM
Black2na
Joined Jul 3, '05
my favorite quote from when i had my Supercharged IS
Friend: So how much fun is that car
Me: about 9MPG worth
so yeah everything is dependant on the go stick. but you can't have a fast car and never get into it. that wouldn't be any fun would it!
This post has been edited by Black2na: Oct 1, 2007 - 9:47 PM
2002 Supercharged IS300
post Oct 4, 2007 - 12:27 AM
6strngs
Joined May 12, '06
From Wilmington, NC
so.. 240whp on pump gas vs. your 235whp on race gas... why do you think it made more power than yours manny? obviously it's a different turbo, but could just the turbo, bigger intercooler, and slightly larger IC piping really make that difference? I know it's only 5 hp more, but yours was on race gas, your pump gas numebr was like 215 or so wasn't it? which would be 25 more hp... now that's a lot!
post Oct 4, 2007 - 2:07 AM
QUOTE(6strngs @ Oct 4, 2007 - 1:27 AM) [snapback]601420[/snapback]
because its a bigger turbo.
bigger turbos will produce more power, at less boost, but with more lag as a side effect.
post Oct 4, 2007 - 5:45 AM
QUOTE(lagos @ Oct 4, 2007 - 3:07 AM) [snapback]601452[/snapback]
bigger, more effecient turbo.
and a bit of tuning experience on my part.
post Oct 4, 2007 - 9:57 AM
99GT
Joined Dec 14, '06
From MN, USA
Are you/they plan to run that setup at 11 daily? Will internals last long?
post Oct 4, 2007 - 11:26 AM
QUOTE(99GT @ Oct 4, 2007 - 10:57 AM) [snapback]601510[/snapback]
i dont see a problem with them running @ this boost level for as long as they want to, as long as the turbo holds up.
ive been running my setup @ over 12psi for over 2 yrs now, over 30k miles.
as long as its tuned, and not knocking itself to peices, the internals are just fine in the 5sfe.
especially the newer (98+) blocks.
i would think nothing of driving this car, everyday, at this boost level.
i've pushed mine ALOT harder than this car will be.
now, going up from here, its all new ground.
who knows how much more it can take.
if it were my car, i would go back, with some race gas in there, and crank the boost up a few more psi, just to see if we've gotten to the limit of what the head can flow, hp wise.
dustins (batman722)car will be the one who tells the story on that one, once he gets his cams installed, and the turbo on a while after that.
post Oct 7, 2007 - 2:36 PM
Kadett
Joined Mar 17, '05
From The Netherlands
To anyone that worked on the car, what did you use as ground connection for the ground wire to attach to from the battery. I want to move my battery but still cant find a descent spot to connect the ground wire to.
post Oct 7, 2007 - 2:39 PM
QUOTE(Kadett @ Oct 7, 2007 - 3:36 PM) [snapback]602633[/snapback]
for the ground in the trunk, there are a bunch of bolts that you can gound to.
dustin hooked it into a bolt against the rear panel,behind the hatch plastic.
post Oct 8, 2007 - 2:41 AM
malpaso
Joined Feb 3, '06
From Czech Republic (Europe)
post Oct 9, 2007 - 7:04 PM
eggman40
Joined Aug 17, '04
From California
post Oct 18, 2007 - 10:51 AM
99GT
Joined Dec 14, '06
From MN, USA
Any updates?
post Oct 18, 2007 - 10:56 AM
QUOTE(99GT @ Oct 18, 2007 - 11:51 AM) [snapback]606144[/snapback]
Any updates?
not really, the car runs and drives beautifly, got painted yesterday, and will be delivered to them tommorow.
post Oct 18, 2007 - 2:39 PM
Rdizzle
Joined Jul 17, '06
From Gig Harbor
Any way you could post the AFC tune? I actually have a similar turbo and so forth ironically, so that would waaay cut down on the massive expense of this
You can't spell overreacting without ovary.
post Oct 18, 2007 - 4:08 PM
QUOTE(Rdizzle @ Oct 18, 2007 - 3:39 PM) [snapback]606223[/snapback]
no, every car requires its own tune.
post Oct 18, 2007 - 4:57 PM
jcbass7
Joined Apr 20, '06
From Florida
QUOTE(presure2 @ Oct 18, 2007 - 11:56 AM) [snapback]606146[/snapback]
Any updates?
any pics of the new paint manny?
post Oct 18, 2007 - 5:34 PM
QUOTE(jcbass7 @ Oct 18, 2007 - 5:57 PM) [snapback]606263[/snapback]
http://www.6gc.net/forums/index.php?showto...8805&st=720
post Oct 18, 2007 - 5:45 PM
Any updates?
yup, i posted a couple in the post a pic thread in the media section.
here they are.
Lo-Fi Version Time is now: April 23rd, 2025 - 8:04 PM
