Abnormal Tire wear |
Sep 29, 2007 - 11:36 PM |
Enthusiast Joined May 3, '06 From New Hampshire Currently Offline Reputation: 2 (100%) |
So after I repainted my rims this winter i had them balanced this spring on the inside instead of the outside like they were before ( i took the weights off to repaint). Well they looked good but i had some vibration over 70mph, but i rarely go over 70 bc of where i live. I know i talked to migga and jeff and they say its a common vibration but i didn't have it when i had my rims balanced with weights on the outside.
Now only my drivers side tire has wear in the middle of the tire, and i check my tire pressure every couple of weeks to make sure they are at the right level. So do I have wear bc of balancing on the inside or do i possibly have a bad drivers side ??????. I know that there are no CV problems, clunking or noise coming from my suspension. When i brake there is no vibrations to indicate a worn rotor, and wouldn't an alignment affect both tires? What do you think? Bad tire? Balancing? A bad part that isn't normally noticable? S.O.L.....?? BTW I run on Falken 512's.... -------------------- Darin H. |
Sep 30, 2007 - 4:22 PM |
QUOTE(6gcSTVT @ Sep 30, 2007 - 12:36 AM) [snapback]600181[/snapback] So after I repainted my rims this winter i had them balanced this spring on the inside instead of the outside like they were before ( i took the weights off to repaint). Well they looked good but i had some vibration over 70mph, but i rarely go over 70 bc of where i live. I know i talked to migga and jeff and they say its a common vibration but i didn't have it when i had my rims balanced with weights on the outside. Now only my drivers side tire has wear in the middle of the tire, and i check my tire pressure every couple of weeks to make sure they are at the right level. So do I have wear bc of balancing on the inside or do i possibly have a bad drivers side ??????. I know that there are no CV problems, clunking or noise coming from my suspension. When i brake there is no vibrations to indicate a worn rotor, and wouldn't an alignment affect both tires? What do you think? Bad tire? Balancing? A bad part that isn't normally noticable? S.O.L.....?? BTW I run on Falken 512's.... normally if the tires wear more in the middle its from overinflation, but seems odd in your case since you check tire pressure. i wouldnt think it would be caused by the weights -------------------- Former Team 5SFTE pro member ;)
13.6@108MPH, 5SFTE Powered |
Lo-Fi Version | Time is now: December 3rd, 2024 - 11:35 PM |
